HP ZBook 14 Mobile Workstation - Spare Parts
New Model Specific Parts List
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website.
Computer Major Components
Figure : Computer major components
Item
Component
Spare Part Number
1
Display assembly: Non-touch display assemblies are spared at the subcomponent level only.
Touch screen display assemblies are only spared as whole units.
14.0-inch HD+ LED AntiGlare SVA touchscreen display assembly - 1920 x 1080 maximum resolution, 250 nits brightness
737735-001
739848-001
2
Keyboard (includes cables)
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (United States)
730794-xx1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (United States)
731179-xx1
3
Top cover (includes TouchPad)
Upper CPU cover (chassis top) - Includes TouchPad assembly - For use with ZBook 14 models
730965-001
4
Power button board
For use on HP EliteBook 840/HP ZBook 14 models
730959-001
5
Battery for real time clock (RTC) - Includes connector cable and double-sided tape
665733-001
6
Card reader board
Card reader board - For use in EliteBook 840 and ZBook 14 models
730955-001
7
Speaker assembly (includes connector cable)
730798-001
8
VGA/USB board
For use in HP EliteBook 840/HP ZBook 14 models
730966-001
9
Fingerprint reader board (includes cable, bracket, and insulator)
730956-001
10
Battery (Li ion)
3-cell lithium-ion (Li-Ion), 4.5Ah, 50Wh (CM03050XL-PL)
717376-001
3-cell lithium-ion (Li-Ion), 2.4Ah, 24Wh (CM03024XL-PL)
717375-001
11
Fan assembly - Includes connector cable
730792-001
12
Hard drive (does not include hard drive bracket, connector, or screws)
1TB, 5400-rpm, 2.5 inch
676521-001
500GB, 7200-rpm, 7-mm, SED
703268-001
500GB, 7200-rpm, 2.5-inch, SED
683801-001
500GB, 7200-rpm, 7 mm
703267-001
500GB, 5400-rpm, 7 mm
683802-001
500GB, 5400-rpm, 7-mm, FIPS
730946-001
320GB, 7200-rpm, 7 mm
634862-001
320GB, 5400-rpm, 7 mm
645193-001
Hard Drive Hardware Kit (not illustrated, includes hard drive bracket and screws)
730793-001
13
Heat sink (thermal module) - For use in EliteBook 840 and ZBook 14 models with discrete graphics - Includes replacement thermal material
730962-001
14
For use only on HP EliteBook 840/HP ZBook 14 models with UMA graphics
730963-001
Memory modules (PC3L, 12800, 1600-MHz)
8GB memory module
693374-001
4GB memory module
691740-001
16
System board (includes replacement thermal material)
For use on models with UMA graphics and an Intel Core i5-4300U processor for use with the Windows 8 Professional operating system
730803-601
For use on models with UMA graphics and an Intel Core i5-4300U processor for use with the Windows 8 Standard operating system
730803-501
For use on models with UMA graphics and an Intel Core i5-4300U processor for use with models without the Windows 8 operating system
730803-001
For use on models with discrete graphics and an Intel Core i5-4300U processor for use with the Windows 8 Professional operating system
730804-601
For use on models with discrete graphics and an Intel Core i5-4300U processor for use with the Windows 8 Standard operating system
730804-501
For use on models with discrete graphics and an Intel Core i5-4300U processor for use with models without the Windows 8 operating system
730804-001
For use on models with UMA graphics and an Intel Core i3-4010U processor for use with the Windows 8 Professional operating system
730805-601
For use on models with UMA graphics and an Intel Core i3-4010U processor for use with the Windows 8 Standard operating system
730805-501
For use on models with UMA graphics and an Intel Core i3-4010U processor for use with models without the Windows 8 operating system
730805-001
For use on models with discrete graphics and an Intel Core i3-4010U processor for use with the Windows 8 Professional operating system
730806-601
For use on models with discrete graphics and an Intel Core i3-4010U processor for use with the Windows 8 Standard operating system
730806-501
For use on models with discrete graphics and an Intel Core i3-4010U processor for use with models without the Windows 8 operating system
730806-001
For use on models with UMA graphics and an Intel Core i5-4200U processor for use with the Windows 8 Professional operating system
730807-601
For use on models with UMA graphics and an Intel Core i5-4200U processor for use with the Windows 8 Standard operating system
730807-501
For use on models with UMA graphics and an Intel Core i5-4200U processor for use with models without the Windows 8 operating system
730807-001
For use on models with discrete graphics and an Intel Core i5-4200U processor for use with the Windows 8 Professional operating system
730808-601
For use on models with discrete graphics and an Intel Core i5-4200U processor for use with the Windows 8 Standard operating system
730808-501
For use on models with discrete graphics and an Intel Core i5-4200U processor for use with models without the Windows 8 operating system
730808-001
System board (motherboard) - Includes an Intel Core i7-4600U processor (2.1GHz, 4MB Level-3 cache, 15W TDP) with Mobile Intel QM87 chipset - For use on models with dedicated graphics and Windows 8 Professional operating system
730809-601
System board (motherboard) - Includes an Intel Core i7-4600U processor (2.1GHz, 4MB Level-3 cache, 15W TDP) with Mobile Intel QM87 chipset - For use on models with dedicated graphics and Windows 8 operating system
730809-501
System board (motherboard) - Includes an Intel Core i7-4600U processor (2.1GHz, 4MB Level-3 cache, 15W TDP) with Mobile Intel QM87 chipset - For use on models with dedicated graphics and without the Windows 8 operating system
730809-001
For use on models with discrete graphics and an Intel Core i7-4600U processor for use with the Windows 8 Professional operating system
730810-601
For use on models with discrete graphics and an Intel Core i7-4600U processor for use with the Windows 8 Standard operating system
730810-501
For use on models with discrete graphics and an Intel Core i7-4600U processor for use with models without the Windows 8 operating system
730810-001
17
WLAN module
Intel Dual Band Wireless-AC 7260 802.11a/c 2x2 WiFi + BT 4.0
710661-001
Intel Dual Band Wireless-N 7260AN 802.11a/b/g/n 2x2 WiFi + BT4.0
717381-001
Intel Dual Band Wireless-N 7260NB 802.11a/b/g/n 2x2 WiFi + BT4.0
717382-001
Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi + BT 4.0 Combo Adapter
731550-001
18
WWAN module
HP lt4111 LTE/EV-DO/HSPA+ Mobile Broadband Module
704030-001
HP lt4112 LTE/HSPA+ Gobi 4G Module
704031-001
HP hs3110 HSPA+ Mobile Broadband Module
723895-001
19
Base enclosure (includes RJ-45 door with spring)
For use only on HP ZBook 14 models
730951-001
Rubber Kit (not illustrated; includes rubber screw covers)
730796-001
20
Solid-state drive (SSD) (includes hard drive bracket and screws)
256GB, Self-encrypting drive (SED)
731194-001
240GB
732680-001
180GB
732678-001
128GB (for use only in HP EliteBook 15 models)
744483-001
120GB
732681-001
32GB
743008-001
21
Service cover
For use only on HP EliteBook 840/HP ZBook 14 models; RCTO
745311-001
730961-001
For use only on HP ZBook 14 models; no CCC mark
745314-001
Display Assembly Subcomponents
Figure : Display components
Item
Component
Spare Part Number
1
Display bezel
For use on HP ZBook 14 models
730953-001
2
730542-001
Microphone module (not illustrated)
730795-001
3
Antenna cables and transceivers (WLAN and WWAN)
730947-001
4
Display panel cable (includes webcam/microphone module cable)
730954-001
5
35.6 cm (14.0 in) LED, AntiGlare display panel
HD, SVA (1366×768), 200 nits
737657-001
HD+, SVA (1920×1080), 250 nits
737658-001
FHD, SVA (1920×1080) 300 nits
737659-001
6
Display Hinge Kit (includes left and right hinges and hinge covers)
For use in HP ZBook 14 models
737660-001
7
Display enclosure (includes 4 transceivers with antennas)
730948-001
Mass Storage Devices
Figure : Storage device
Item
Spare Part Number
1
Hard Drive Hardware Kit, includes bracket
730793-001
2
Hard drive (does not include hard drive bracket or screws)
676521-001
703268-001
683801-001
703267-001
683802-001
730946-001
634862-001
645193-001
3
Solid-state drive (includes hard drive bracket and screws)
731194-001
240GB
732680-001
180GB
732678-001
Plastics Kit
Figure : Plastic kit
Item
Spare Part Number
Plastics Kit for use only on HP ZBook 14 models
739558-001
1
SD card insert, illustrated
2
Fingerprint reader insert
3
RJ-45 spring
4
RJ-45 door
Miscellaneous Parts
Component
Spare Part Number
90-W HP Smart AC adapter (PFC)
693712-001
45-W HP Smart AC adapter (non-PFC, EM, 3-wire)
696694-001
65-W HP Smart AC travel adapter (non-PFC)
693716-001
65-W HP Smart AC adapter (non-PFC, 3-wire)
693711-001
65-W HP Smart AC adapter (RC/V, EM, 3-wire) for use in India and the People’s Republic of China
693710-001
Power cord (3-pin, black, 1.83 m)
For use in Argentina
490371-D01
For use in Australia
490371-011
For use in Brazil
490371-202
For use in Denmark
490371-081
For use in Europe
490371-021
For use in India
490371-D61
For use in Israel
490371-BB1
For use in Italy
490371-061
For use in Japan
490371-291
For use in North America
490371-001
For use in the People's Republic of China
490371-AA1
For use in South Africa
490371-AR1
For use in South Korea
490371-AD1
For use in Switzerland
490371-111
For use in Taiwan
490371-AB1
For use in Thailand
490371-201
For use in the United Kingdom and Singapore
490371-031
Cable lock
575921-001
Mouse
USB, optical, travel
434594-001
USB, laser
674318-001
Screw Kit
730797-001
Cases
Top load case
679921-001
HP Business Slim Top Load Case
718549-001
HP Business Top Load Case
718550-001
Display Port to HDMI adapter
617450-001
Sequential Part Number Listing
Spare Part Number
Mouse, USB, travel
434594-001
Power cord for use on all computer models in North America (3-pin, black, 1.83 m)
490371-001
Power cord for use on all computer models in Australia (3-pin, black, 1.83 m)
490371-011
Power cord for use on all computer models in Europe (3-pin, black, 1.83 m)
490371-021
Power cord for use on all computer models in the United Kingdom and Singapore (3-pin, black, 1.83 m)
490371-031
Power cord for use on all computer models in Italy (3-pin, black, 1.83 m)
490371-061
Power cord for use on all computer models in Denmark (3-pin, black, 1.83-m)
490371-081
Power cord for use on all computer models in Switzerland (3-pin, black, 1.83-m)
490371-111
Power cord for use on all computer models in Thailand (3-pin, black, 1.83 m)
490371-201
Power cord for use on all computer models in Brazil (3-pin, black, 1.83 m)
490371-202
Power cord for use on all computer models in Japan (3-pin, black, 1.83 m)
490371-291
Power cord for use on all computer models in the People's Republic of China (3-pin, black, 1.83 m)
490371-AA1
Power cord for use on all computer models in Taiwan (3-pin, black, 1.83 m)
490371-AB1
Power cord for use on all computer models in South Korea (3-pin, black, 1.83 m)
490371-AD1
Power cord for use on all computer models in South Africa (3-pin, black, 1.83 m)
490371-AR1
Power cord for use on all computer models in Israel (3-pin, black, 1.83-m)
490371-BB1
Power cord for use on all computer models in Argentina (3-pin, black, 1.83 m)
490371-D01
Power cord for use on all computer models in India (3-pin, black, 1.83-m)
490371-D61
Intel Centrino Ultimate-N 6300 WLAN module
572511-001
Cable lock
575921-001
617450-001
320GB, 5400-rpm, 7-mm hard drive (does not include hard drive bracket or screws)
634862-001
645193-001
1TB, 5400-rpm, 2.5-inch hard drive (does not include hard drive bracket or screws)
676521-001
RTC battery
665733-001
Service cover (regional configure to order [RCTO] with “made in America” or “made in Mexico” label)
670434-001
Service cover (regional configure to order [RCTO] with “made in Japan” label)
671461-001
Mouse, USB, laser
674318-001
HP lt2522 LTE/EV-DO Mobile Broadband Module
675791-001
HP lt2523 LTE/HSPA+ Mobile Broadband Module
675793-001
Atheros WB225 1×1 802.11b/g/n Bluetooth Combo Adapter
675794-001
Top load case
679921-001
500GB, 7200-rpm, 2.5-inch, SED hard drive (does not include hard drive bracket or screws)
683801-001
500GB, 5400-rpm, 7-mm hard drive (does not include hard drive bracket or screws)
683802-001
128GB solid-state drive (does not include bracket, connector cable, or screws)
690406-001
4GB memory module (PC3L, 12800, 1600-MHz)
691740-001
160-GB solid-state drive (does not include bracket, connector cable, or screws)
693298-001
8GB memory module (PC3L, 12800, 1600-MHz)
693374-001
693710-001
693711-001
693712-001
90-W HP Smart AC travel adapter (non-PFC)
693716-001
696694-001
180GB solid-state drive (does not include bracket, connector cable, or screws)
700372-001
240GB solid-state drive (does not include bracket, connector cable, or screws)
702243-001
500GB, 7200-rpm, 7-mm hard drive (does not include hard drive bracket or screws)
703267-001
500GB, 7200-rpm, 7-mm, SED hard drive (does not include hard drive bracket or screws)
703268-001
704030-001
704031-001
4GB Samsung locked memory module (PC3, 12800, 1600-MHz)
707031-001
3-cell, 24-Wh, 2.40-Ah, Li-ion battery
717375-001
3-cell, 50-Wh, 4.50-Ah, Li-ion battery
717376-001
Intel Dual Band Wireless-N 7260AN 802.11 a/b/g/n 2x2 WiFi + BT4.0
717381-001
Intel Dual Band Wireless-N 7260NB 802.11 a/b/g/n 2x2 WiFi + BT4.0
717382-001
718549-001
718550-001
723895-001
Webcam module
730542-001
Fan (includes cable)
730792-001
Hard Drive Hardware Kit (includes the hard drive bracket and screws)
730793-001
730794-001
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (United Kingdom)
730794-031
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Germany)
730794-041
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (France)
730794-051
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Italy)
730794-061
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Spain)
730794-071
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Denmark)
730794-081
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Norway)
730794-091
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Portugal)
730794-131
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Turkey)
730794-141
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Greece)
730794-151
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Latin America)
730794-161
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Saudi Arabia)
730794-171
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Brazil)
730794-201
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Hungary)
730794-211
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Russia)
730794-251
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Bulgaria)
730794-261
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Romania)
730794-271
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Thailand)
730794-281
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Japan)
730794-291
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Belgium)
730794-A41
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Taiwan)
730794-AB1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (South Korea)
730794-AD1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Netherlands)
730794-B31
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Sweden and Finland)
730794-B71
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Slovenia)
730794-BA1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Israel)
730794-BB1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Switzerland)
730794-BG1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (India)
730794-D61
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Canada)
730794-DB1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Iceland)
730794-DD1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Czech Republic and Slovakia)
730794-FL1
Keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Northwest Africa)
730794-FP1
Microphone module
730795-001
Rubber Kit (includes rubber screw covers)
730796-001
Screw Kit
730797-001
Speaker assembly (includes cable)
730798-001
Top cover for use only on HP EliiteBook 850 models (includes TouchPad)
730800-001
Display panel cable for use only on HP EliteBook 850 models
730801-001
Plastics Kit for use only on HP EliteBook 850 models (includes SD card insert, RJ-45 door, fingerprint reader insert, and RJ-45 spring)
730802-001
System board with UMA graphics and an Intel Core i5-4300U processor for use in models without the Windows 8 operating system
730803-001
System board with UMA graphics and an Intel Core i5-4300U processor for use with the Windows 8 Standard operating system
730803-501
System board with UMA graphics and an Intel Core i5-4300U processor for use with the Windows 8 Professional operating system
730803-601
System board with discrete graphics and an Intel Core i5-4300U processor for use with models without the Windows 8 operating system
730804-001
System board with discrete graphics and an Intel Core i5-4300U processor for use with the Windows 8 Standard operating system
730804-501
System board with discrete graphics and an Intel Core i5-4300U processor for use with the Windows 8 Professional operating system
730804-601
System board with UMA graphics and an Intel Core i3-4010U processor for use in models without the Windows 8 operating system
730805-001
System board with UMA graphics and an Intel Core i3-4010U processor for use with the Windows 8 Standard operating system
730805-501
System board with UMA graphics and an Intel Core i3-4010U processor for use with the Windows 8 Professional operating system
730805-601
System board with discrete graphics and an Intel Core i3-4010U processor for use in models without the Windows 8 operating system
730806-001
System board with discrete graphics and an Intel Core i3-4010U processor for use with the Windows 8 Standard operating system
730806-501
System board with discrete graphics and an Intel Core i3-4010U processor for use with the Windows 8 Professional operating system
730806-601
System board with UMA graphics and an Intel Core i5-4200U processor for use in models without the Windows 8 operating system
730807-001
System board with UMA graphics and an Intel Core i5-4200U processor for use with the Windows 8 Standard operating system
730807-501
System board with UMA graphics and an Intel Core i5-4200U processor for use with the Windows 8 Professional operating system
730807-601
System board with discrete graphics and an Intel Core i5-4200U processor for use in models without the Windows 8 operating system
730808-001
System board with discrete graphics and an Intel Core i5-4200U processor for use with the Windows 8 Standard operating system
730808-501
System board with discrete graphics and an Intel Core i5-4200U processor for use with the Windows 8 Professional operating system
730808-601
730809-001
730809-501
730809-601
System board with discrete graphics and an Intel Core i7-4600U processor for use in models without the Windows 8 operating system
730810-001
System board with discrete graphics and an Intel Core i7-4600U processor for use with the Windows 8 Standard operating system
730810-501
System board with discrete graphics and an Intel Core i7-4600U processor for use with the Windows 8 Professional operating system
730810-601
Display enclosure for use in HP EliteBook 850 models (includes 4 transceivers with antennas)
730811-001
Service cover for use only on HP EliteBook 850 models
730812-001
Base enclosure for use only on HP EliteBook 850 models (includes RJ-45 door with spring)
730813-001
Display bezel for use only on HP EliteBook 850 models
730814-001
Heat sink for use only on HP EliteBook 850 models with UMA graphics (includes replacement thermal material)
730815-001
Fingerprint reader assembly for use in HP EliteBook 850 models (includes cable, bracket, and insulator)
730817-001
Display Hinge Kit for use only on HP EliteBook 850 models (includes left and right hinges and hinge covers)
730819-001
VGA/USB board for use in HP EliteBook 850 models
730820-001
Card reader board for use in HP EliteBook 850 models
730821-001
Power button board for use in HP EliteBook 850 models
730822-001
500-GB, 5400-rpm, 7-mm, FIPS hard drive (does not include hard drive bracket or screws)
730946-001
Antennas (WLAN, WWAN) for use only on HP EliteBook 840/HP ZBook 14 models
730947-001
Display enclosure for use in HP ZBook 14 models (includes 4 transceivers with antennas)
730948-001
Display enclosure for use in HP EliteBook 840 models (includes 4 transceivers with antennas)
730949-001
Base enclosure for use only on HP EliteBook 840 models (includes RJ-45 door with spring)
730950-001
Base enclosure for use only on HP ZBook 14 models
730951-001
Display bezel for use only on HP EliteBook 840 models
730952-001
Display bezel for use only on HP ZBook 14 models
730953-001
Display panel cable for use only on HP EliteBook 840/HP ZBook 14 models
730954-001
Card reader board for use in HP EliteBook 840/ZBook 14 models
730955-001
Fingerprint reader assembly for use in HP EliteBook 840/HP ZBook 14 models (includes cable, bracket, and insulator)
730956-001
Display Hinge Kit for use only on HP EliteBook 840 models (includes left and right hinges and hinge covers)
730957-001
Plastics Kit for use only on HP EliteBook 840 models (includes SD card insert, RJ-45 door, fingerprint reader insert, and RJ-45 spring)
730958-001
Power button board for use in HP EliteBook 840/HP ZBook 14 models
730959-001
Service cover for use only on HP EliteBook 840 models
730960-001
Service cover for use only on HP ZBook 14 models
730961-001
Heat sink for use only on HP EliteBook 840/HP ZBook 14 models with discrete graphics (includes replacement thermal material)
730962-001
Heat sink for use only on HP EliteBook 840/HP ZBook 14 models with UMA graphics (includes replacement thermal material)
730963-001
SPS-TOP COVER 14
730964-001
Top cover for use only on HP EZBook 14 models (includes TouchPad)
730965-001
VGA/USB board for use in HP EliteBook 840/HP ZBook 14 models
730966-001
731179-001
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (United Kingdom)
731179-031
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Germany)
731179-041
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Frames)
731179-051
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Italy)
731179-061
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Spain)
731179-071
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Denmark)
731179-081
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Norway)
731179-091
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Portugal)
731179-131
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Turkey)
731179-141
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Greece)
731179-151
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Latin America)
731179-161
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Saudi Arabia)
731179-171
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Brazil)
731179-201
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Hungary)
731179-211
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Russia)
731179-251
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Bulgaria)
731179-261
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Romania)
731179-271
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Thailand)
731179-281
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Japan)
731179-291
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Belgium)
731179-A41
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Taiwan)
731179-AB1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (South Korea)
731179-AD1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Netherlands)
731179-B31
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Sweden)
731179-B71
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Slovenia)
731179-BA1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Israel)
731179-BB1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Switzerland)
731179-BG1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (India)
731179-D61
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Canada)
731179-DB1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Iceland)
731179-DD1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Czech Republic and Slovakia)
731179-FL1
Backlit keyboard with Dualpoint pointing stick - Spill-resistant design with drain and DuraKeys - Includes keyboard cable and pointing stick cable (Northwest Africa)
731179-FP1
Solid-state drive, 256GB, Self-encrypting drive (SED) (includes hard drive bracket and screws)
731194-001
Broadcom BCM943228HMB 802.11a/b/g/n 2x2 Wi-Fi + BT 4.0 Combo Adapter
731550-001
Heat sink for use only on HP EliteBook 850 models with discrete graphics (includes replacement thermal material)
732626-001
Solid-state drive, 180GB (includes hard drive bracket and screws)
732678-001
Solid-state drive, 240GB (includes hard drive bracket and screws)
732680-001
Solid-state drive, 120GB (includes hard drive bracket and screws)
732681-001
Raw display panel, (39.6-cm) 15.6-in LED, HD, AG, SVA (1368×768), 300 nits
733684-001
Raw display panel, (39.6-cm) 15.6-in LED, FHD, AG, SVA (1920×1080), 200 nits
733685-001
Antennas (WLAN, WWAN) for use only on HP EliteBook 850 models
736678-001
Raw display panel, (35.6-cm) 14.0-in LED, HD, AntiGlare (AG), SVA (1366×768), 200 nits
737657-001
Raw display panel, (35.6-cm) 14.0-in LED, HD+, AG, SVA (1920×1080), 250 nits
737658-001
Raw display panel, (35.6-cm) 14.0-in LED, FHD, AG, SVA (1920×1080), 300 nits
737659-001
Display Hinge Kit for use only on HP ZBook 14 models (includes left and right hinges and hinge covers)
737660-001
Display assembly, 14-inch, HD+, for use in HP EliteBook 840 models
737735-001
Plastics Kit for use only on HP ZBook 14 models (includes SD card insert, RJ-45 door, fingerprint reader insert, and RJ-45 spring)
739558-001
Display assembly, 14-inch, HD+, for use in HP ZBook 14 models
739848-001
Solid-state drive, 32GB (includes hard drive bracket and screws)
743008-001
Solid-state drive, 128GB (includes hard drive bracket and screws); for use only in HP EliteBook 15 models
744483-001
Service cover for use only on HP EliteBook 850 models; without CCC mark
745309-001
Service cover for use only on HP EliteBook 850 models; for RCTO
745310-001
Service cover for use only on HP EliteBook 840/HP ZBook 14 models; RCTO
745311-001
Service cover for use only on HP EliteBook 840 models; no CCC mark
745313-001
Service cover for use only on HP ZBook 14 models; no CCC mark
745314-001
