Product Name
6002ra
Product Number
G1W00PA
Chipset and Microprocessor
Marvel SOC PXA1088 quad-core
1.2 GHx SoC (BGA)
Integrated graphics
Integrated Marvell 88L1000 GPS Hybrid Location Processor
SI-EN SN4832 dual 2.5 W audio power amplifier and stereo headphone driver
Video engine
LP DDR2 memory controller
Support 3G cellular protocols
Supports eMMC
Memory
1 GB LP DDR2 - 533 MHz
16 GB embedded MultiMediaCard (eMMC)
microSD up to 32 GB (also supports SDHC)
15.24 cm (6 inch) display
Native resolution: 1280x720
5-finger capacitive multi-touch touchscreen
400 nits
WLAN: Marvell 88W8787 WiFi/BT 4.0/FM combo w/ 1 x 1 antenna ; supports 802.11b/ g/ n, but Bluetooth is actually 3.0 due to SW driver/stack limitation
WWAN: 3G data enabled
Network
Optimized for voice calling
GSM at 850/900/1800/1900 MHz
WCDMA at 900/2100 MHz primary with a printed circuit board (PCB) design to support 850/2100 MHz
Dual SIM Dual Standby: 1 microSIM (WCDMA/GSM ) and 1 Mini SIM (GSM)
Audio
1 digital microphone
Integrated stereo speakers
Stereo FM radio
External Ports
Micro SD Card Slot supported up to 32GB
Input / Output
3.5mm 4-pole headset jack
1 microUSB 2.0; Type B connector (supports charging Host Mode only)
microSD slot
Dimensions
83.2 mm (width) x 165.1mm (depth) x 8.98 mm (height)
160 g (0.35 lbs)
Sensors
Ambient Light sensor
Accelerometer
e-Compass
GPS
aGPS
Gyro
Proximity
Power
Battery: 3000 mAh lithium-ion
AC adapter:
5V-2A (10W) duckhead - microUSB-USB cable connects adapter to tablet
USB cable
Front: 2 MP fixed focus camera without webcam indicator LED
Back:: 5 MP camera with auto focus and LED flash, HD video recording, 720P HD video
Buttons
Power
Volume Up / Volume Down
- ${title}
- ${title}
- ${title}
- ${title}
HP Slate 6 6002ra VoiceTab Product Specifications
Operating System:
Android 4.2 .2
Google Software:
Chrome
Gmail
Google Search
Google+
Google Maps
Google Photos
Googel Voice Search
YouTube
HP Software:
HP ePring
HP Wallpaper
HP Connected Photo
HP File Manager
HP Registration
HP Startup animation
HP Homescreen Layout
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
