    Fix HP Printer issue on macOS
HP EliteBook Revolve 810 G1 Tablet Product Specifications
Product description
HP EliteBook Revolve 810 Tablet is an ultra-thin, full-performance Windows notebook that transforms into a tablet.
  • No compromise performance
  • Designed for durability
  • Deploy, manage, and secure with ease
Product features
Feature
Graphics
Integrated: Intel HD Graphics
  • Internal: 11.6-inch diagonal LED-backlit HD UWVA touchscreen (1366 x 768)
    • Ultra- Wide-viewing angle
    • Capacitive multi touch screen with digitizer
    • Tough, durable Corning Gorilla Glass 2
  • External: Up to 32-bit per pixel color depth
  • DisplayPort: Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
Storage and drives
Up to 256GB mSATA
Memory
  • Standard:
    • DDR3L PC3-12800 SDRAM (1600 MHz)
    • One SODIMM slot supporting dual-channel memory plus 4GB soldered down
    • 4GB and 8GB SODIMMs
  • Maximum:
    • Upgradeable to 12288MB with optional 8192 MB SODIMM in slot 1 and 4096MB soldered down
    • Dual-channel
    • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots
Audio/Multimedia
  • Audio:
    • DTS Studio Sound
    • Integrated stereo speakers
    • Integrated microphone (dual-microphone array)
    • Buttons for volume up and down
    • Headphone/microphone combo jack
  • Webcam: Integrated 720p HD webcam
    • HD format (widescreen)
    • Supports videoconferencing and still image capture
    • High quality fixed focus lens
    • Video capture at various resolutions up to 1280 x 720 resolution (720 p) and up to 30 f/s
    • M-JPEG compression supports higher frame rates for video capture and videoconferencing
    • Improved low light sensitivity
    • Improved dynamic range
System unit specifications
Specification
Stand-Alone power requirements (AC Power)
Nominal operating voltage
110/220 V
Average operating power
10.2 W
Max operating power
< 45 W
Temperature
Operating
  • Not writing optical: 0° to 35°C (32° to 95°F)
  • Writing optical: 5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 g
Non-operating
1.50 g
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
11.6-inch LED HD (1366 x 768)
Specification
Active area
25.61 x 14.40 cm (9.88 x 5.67 in)
Dimensions (W x H)
29.3 x 16.5 cm (11.53 x 6.49 in)
Diagonal size
29.46 cm (11.6 in)
Contrast ratio
300:1 (typical)
Refresh rate
60 Hz
Brightness
400 nits (typical)
Pixel resolution
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
Viewing angle
40/40/15/30 (Left/Right/Down/Up) (typical)
Storage & drives specifications
Internal storage
128GB mSATA Solid State Drive (SSD)
Specification
Drive Weight
10 G
Capacity
128GB
Height
3.75 mm (0.147 in)
Width
29.85 mm (1.18 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up to 450 MB/s
  • Maximum sequential write: Up to 260 MB/s
Logical blocks
250,069,680
Operating temperature
0° to 70°C (32° to 158°F)
Features
ATA Security; ATA-8; SATA 3.0; DIPM
256GB mSATA SSD
Specification
Drive weight
Upto 10 G
Capacity
128GB
Height
Up to 4.85 mm (Up to 0.191 in)
Width
29.85 mm (1.18 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up to 490 MB/s
  • Maximum sequential write: Up to 250 MB/s
Logical blocks
500,118,192
Features
ATA Security; ATA-8, SATA 3.0; DIPM; TRIM
Networking & communication specifications
Intel 82579LM Gigabit Network Connection
Specification
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) Support IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power management
  • ACPI compliant - multiple power modes
  • Energy Detect Low Power Mode (Green Ethernet)
Performance features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload( ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
  • MACSec Offload (802.3ae)
  • Intel vPro
  • iSCSI Boot
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame)
  • Wake-on-LAN from Off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface1
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ.
NIC device driver name
Intel 82579LM/82579V Ethernet Network Connection
1: Intel 82579 PCIe interface is not PCIe compliant. It operates at half of PCIe specification V1.1 (2.5 GT/S) speed.
HP un2430 EV-DO/HSPA Mobile Broadband Module
Specification
Technology/Operating bands
  • GSM/GPRS/EDGE: 850 MHz (Cell), 900 MHz (EGSM), 1800 MHz(DCS), 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), AWS (UTRA FDD Band IV), 900 MHz (UTRA FDD Band VIII), 850MHz (UTRA FDD Band V)
  • 1xEVDO/1xRTT with receive diversity: 850 MHz (Band Class0-Cell), 1900 MHz (Band Class1-PCS)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class A, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • UMTS/WCDMA: Release 99 and Release 6
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
Wireless parametric standards
Meets or exceeds TIA/EIA IS-98-D
Maximum data rates
  • UMTS (HSPA) - 14.4 Mb/s (Download ), 5.76 Mb/s (Upload)
  • CDMA (EVDO Release A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
GPS
  • Standalone GPS enabled
  • gpsOneXTRATM
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • CDMA: 24 dBm (+0.7/-2)
Maximum power consumption
2750 mA (peak); 1100 mA (average)
Power consumption, Idle not connected
20 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express MiniCard, USB 2.0 interface
11.5 g
Dimensions (L x W x T)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, operating
3.3 v +/- 10%
Temperature, operating (from TIA/EIA/IS-98-D)
  • -30° to 70°C (-22° to 158°F) (full RF performance)
  • -30° to 75°C (-22° to 167°F) (reduced RF performance)
Temperature, Non-operating, 96 hours (from MIL-STD 202 Method 108)
40° to 85°C (-40° to 185°F)
Humidity, Non-operating
95% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
Configuration utilities
HP Connection Manager
LED activity
  • LED Off: Radio Off
  • Solid LED On: Radio On
HP hs2350 HSPA+ Mobile Broadband module
Specification
  • UMTS/WCDMA: Release 99 and Release 7
  • Advanced Receiver Type 3i
Complies with 3GPP specifications
Maximum data rates
UMTS (HSPA) - 21 Mbps (Download ), 5.76Mbps (Upload)
GPS
Standalone, A-GPS (Internet- and Network assisted)
GPS bands
1575.42 MHz (± 1.023 MHz)
  • GSM/EDGE
  • GSM850 & GSM900 bands:
    • GPRS: +33 dBm ± 2 dBm (class 4)
    • EGPRS: +27 dBm ± 3 dBm (class E2)
  • DCS1800 & PCS1900 bands:
    • GPRS: +30 dBm ± 2 dBm (class 1)
    • EGPRS: +26 dBm +4/-3 dBm (class E2)
  • UMTS
  • UTRA FDD Bands:
    • +24 dBm +4/-3 dBm (class 3)
2000 mA (peak); 600 mA (average)
5 mA
Power management
Antenna type
Form Factor
< 12 g
Voltage, operating
3.3 v +/- 10%
  • -10° to 65°C (14° to 149°F) (full RF performance)
  • -10° to 75°C (14° to 167°F) (reduced RF performance)
-30° to 85°C (-22° to 185°F)
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
LED activity
Intel Centrino Advanced-N 6205 (2 x 2)
Specification
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP
Frequency band
2.4 GHz and 5 GHz
Antenna structure
2 transmit; 2 receive (2 x 2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 66 possible data rates, ranging from 6 Mb/s to 300 Mbps, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security1
  • Authentication: WPA and WPA2, 802.1x (EAP_TLS, TTLS, PEAP, LEAP, EAPFAST)
  • Authentication Protocols: PAP, CHAP, TLS, GTC, MS-CHAP, MS-CHAPv2
  • Encryption: 64 and 128-bit WEP, AES-CCMP, CKIP, TKIP
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows Vista and XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between 2.4 GHz band Access Points
Output power2 (for CCK and OFDM)
17 dBm max
Power consumption
  • Transmit: 2.3 W (max, with two spatial streams)
  • Receive: 1 W(max with two spatial streams)
  • Idle mode3: 35 mW (average)
  • Radio Off: 20 mW (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity4
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
Antenna connections
2 U.FL type connectors, 50 ohm nominal impedance
Form Factor
PCI-Express Half-MiniCard
3.4 g (0.0075 lb)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Operating voltage
3.3 V +/- 9%
Temperature
  • Operating: 0° to 80°C (32° to 176°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
1: Check latest software/driver release for updates on supported security features.
2: Maximum output power may vary by country according to local regulations.
3: In Power Save Polling mode and on battery power.
4: Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
Intel 802.11a/b/g/n (2x2)
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
Frequency band
2.4 GHz and 5 GHz
Antenna structure
Data rates
Modulation
Security1
Sub-channels
Roaming
17 dBm max
Power consumption
Power management
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
Antenna connections
Form Factor
3.4 g (0.0075 lb)
Dimensions
Operating voltage
3.3 V +/- 9%
Temperature
Humidity
Altitude
LED activity
Audio/Multimedia
Audio
DTS Studio Sound (Windows OS only)
Implementation
IDT 92HD91 High Definition CODEC
Function key volume controls
Volume up, volume down, and mute
Mute buttons
Playback and record mute buttons with LED indicator
Full duplex
Yes
Microphone In
Stereo
Headphone/Line out
Stereo
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz to 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Power rating
1 W
Impedance
8 Ohms
Power specifications
HP 45-W slim smart AC adapter
Dimensions (H x W x D)
9.60 x 4.95 x 2.24 cm
Input
90 to 265 V ac
Input efficiency
87% min at 115 V ac
Input frequency range
47 to 63 Hz
Input AC current
1.4 A at 90 V ac and maximum load
Output
Output power 45 W
DC output
19.5 V
Hold-up time
5 ms at 115 V ac input
Output current limit
< 8A, Over voltage protection -29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Non-operating (storage) temperature
-20° to 85°C (-4° to 121°F)
Altitude
0 to 5,000 m (0 to 16,405 ft)
Humidity
0% to 95%
Storage humidity
0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
HP 6-cell (44 WHr) polymer primary battery
Dimensions (H x W x L)
1.11 x 28.1 x 10.3 cm
Weight (max)
3.10 g
Cells/Type
6-cell polymer
Energy
Voltage
11.1 V
Amp-hour capacity
4.0 Ah
Watt-hour capacity
44 Wh
Temperature
Operating (Charging)
0° to 45°C (32° to 113°F)
Operating (Discharging
-10° to 50°C (14° to 122°F)
Non-operating
-20° to 50°C (-4° to 122°F)
Battery re-charge time
System in Off or standby mode
2.5 hours
System On
3-5 hours
Fuel gauge LED
No
Optional travel battery available
No
Physical specifications
Dimensions (W x D x H)
212 x 285 x 22.2 mm (8.34 x 11.22 x 0.80 in) (at front)
Starting at 1.40 kg (3.08 lb) (weight will vary by configuration)
Software/OS
Feature
Preinstalled
  • HP ePrint
  • PDF Complete Corporate Edition
  • Evernote
  • Adobe Flash Player
  • Cyberlink Media Suite
Environmental specifications
Energy consumption
Specification
115 V ac, 60 Hz
230 V ac, 50 Hz
100 V ac 60 Hz
Normal operation
8.84 W
9.13 W
8.20 W
Sleep
0.78 W
0.9 W
0.78 W
Off
0.39 W
0.48 W
0.38 W
Heat dissipation
Heat Dissipation
115 V ac, 60 Hz
230 V ac, 50 Hz
100 V ac 60 Hz
Normal operation
30 BTU/hr
31 BTU/hr
28 BTU/hr
Sleep
3 BTU/hr
3 BTU/hr
3 BTU/hr
Off
1 BTU/hr
2 BTU/hr
1 BTU/hr
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
