    Looking for Site Help?
HP Color LaserJet Enterprise M651 and HP Color LaserJet Enterprise MFP M680 - Load the 1,500-sheet high-capacity input tray
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Adjust the paper-width guide to the correct position for the paper you are using.
    Figure : Adjust the guides
  3. Rotate the paper-stop lever to the correct position for the paper you are using.
    Figure : Adjust the paper-stop lever
  4. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    To prevent jams, do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
    Figure : Load paper
  5. Close the tray.
    Figure : Close the tray
  6. The tray configuration message displays on the product control panel.
  7. Touch the OK button to accept the detected type and size, or touch the Modify button to choose a different paper size or type.
  8. Select the correct type and size, and then touch the OK button.
Country: Flag Vietnam
