    Apache Log4j Update
HP V206hz 20-inch LED Backlit Monitor - Overview
Product description
Product features
Feature
Type
TN (Twisted Nematic) LED backlit
(20 in) widescreen; diagonally measured
Active area (W x H)
442.8 x 249.075 mm
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical
Brightness (typical)
250 nits (cd/m2)
Contrast ratio (typical)
1000:1
Dynamic contrast ratio (typical)
5,000,000:1
Response rate (typical)
5 ms (On/Off)
Pixel pitch
0.2768 mm x 0.2768 mm
LED lamp life (to half brightness)
30,000 hrs
Color gamut (typical)
72%
Color support
Can display up to 16 million colors with the use of FRC technology
Signal interface/Performance
  • Horizontal frequency: 30 - 83 kHz
  • Vertical frequency: 56 - 75 Hz
  • Native resolution: 1600 x 900 @ 60 Hz
  • Preset VESA graphic modes (non-interlaced):
    • 720 x 400 @ 70 Hz
    • 640 x 480 @ 60 Hz
    • 640 x 480 @75 Hz
    • 800 x 600 @ 60 Hz
    • 800 x 600 @ 75 Hz
    • 1024 x 768 @ 60 Hz
    • 1024 x 768 @ 75 Hz
    • 1280 x 1024 @ 60 Hz
    • 1600 x 900 @ 60 Hz
  • Text mode: 720 x 400 @ 70 Hz
  • Maximum pixel clock speed: 108 MHz
  • User programmable modes: Yes (16)
  • Anti-glare: Yes
  • Default color temperature: Warm (6500° K)
Video/Other inputs
  • Plug and Play: Yes
  • Input connectors: VGA, DVI-D
  • Input impedance: 75 Ohms
  • Sync input: Separate sync(D-sub), Digital(DVI)
  • Video cable: One VGA cable 1.87 m, one DVI cable 1.5 m
  • Video cable lengths: 1.87 m (D-Sub), 1.5 m (DVI-D)
  • Audio: No
