HP Designjet T2500 eMultifunctional Printer Series - Check usage statistics
There are various ways of checking your printer's usage statistics.
The accuracy of the usage statistics is not guaranteed.
From the Embedded Web Server
  1. Access the Embedded Web Server, see Access the Embedded Web ServerAccess the Embedded Web Server.
  2. Go to the Main tab.
  3. Select History > Usage.
From the HP Utility
  1. Access the HP Utility, see Access the HP UtilityAccess the HP Utility.
  2. In the HP Designjet Utility for Windows, go to the Admin tab and open the Embedded Web Server. Then go to the Usage tab in the Embedded Web Server.
    In the HP Utility for Mac OS X, select Information > Printer Usage and press the Lookup button.
From the front panel
  1. Press .
  2. Press .
  3. Press Internal prints.
  4. Press User information prints.
  5. Press Print usage report.
