    Apache Log4j Update
HP ProDisplay P17A 17-inch 5:4 LED Backlit Monitor - Overview
Product description
Product features
Feature
Panel type
Twisted Nematic (TN) LED Backlit LCD
Viewable image area
43.2 cm (17 in), diagonally measured
Viewing angle
  • Horizontal: 170°
  • Vertical: 160°
Brightness1
250 cd/m2
Contrast ratio1
Static: 1000:1
Response rate1
5 ms (On/Off)
Frequency1
  • Horizontal: 24 - 83 KHz
  • Vertical: 50 - 76 Hz
Aspect ratio
5:4
Native resolution
1280 x 1024 @ 60 Hz
Resolutions supported
  • 1280 x 1024 @ 60 Hz
  • 1280 x 800 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Input signal
VGA (analog)
User controls
  • Menu/OK
  • Minus ("-")/Auto
  • Plus ("+")
  • Power
Power consumption
  • Typical: 15.2 W
  • Maximum: 20 W
  • Power saving: 0.5 W
Base features
  • Tilt:
    -5° to +25°
  • Detachable
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
