HP ENVY TouchSmart 14-k112nr Sleekbook PC Product Specifications
Product Name
14-k112nr
Product Number
E0M54UA
1.6GHz 4th generation Intel Core i5-4200U Processor with Turbo Boost up to 2.6GHz
Memory
8GB DDR3L SDRAM (2 DIMM)
Memory Max
Maximum supported = 16GB
Video Graphics
Intel HD graphics 4400 with up to 1792MB total graphics memory
14.0-inch diagonal QHD+ BrightView LED-backlit IPS touchscreen display (3200 x 1800)
Hard Drive
128GB solid-state drive
Network Card
10/100/1000 Gigabit Ethernet LAN (RJ-45 connector)
WWAN
HP hs3114 HSPA+ Mobile Broadband Module
Wireless Connectivity
Intel 1x1 802.11ac WLAN
Bluetooth with WiDi with Intel Smart Connect Technology
Sound
Beats Audio dual speakers and a subwoofer
Keyboard
Full-size island-style backlit keyboard
Pointing Device
HP Clickpad supporting multi-touch gestures without on/off button
External Ports
Multi-format digital media card reader for Secure Digital cards
2 SuperSpeed USB 3.0, 1 supporting USB Boost
1 Universal Serial Bus (USB) 2.0
1 HDMI
1 RJ-45 (LAN)
1 Headphone-out/microphone-in combo jack
Dimensions
0.839 in (max H) x 13.608 in (W) x 9.421 in (D)
4.44 lb
Power
65W AC adapter
3-cell 50WHr 4.56Ah lithium-ion battery
ID Mech Description
Front facing HP TrueVision HD Webcam with integrated dual array digital microphone
Operating System:
Windows 8.1 (64-bit)
Communication Chat:
Skype
HP Help Support:
HP Utility Center: With the HP Utility Center on Windows 8 PCs, get one place to control your settings for all things HP.
Books, Music, Photos, and Videos:
Windows Essentials: Movie Maker; SkyDrive; Photo Gallery
Productivity Tools:
HP Recovery Manager: Recover, restore, and create recovery media for your PC.
Buy Office: The most powerful Office yet. Your content when and where you need it.
Getting Started with Windows 8: HP’s application makes it fun & easy to get to know Windows 8. Let us help you learn the basics of navigating the new Start Screen, powering off your device, and additional tips and tricks through helpful step by step videos.
HP CoolSense technology adjusts its temperature based on usage and conditions. It stays cool. You stay comfortable.
Security Protection:
HP ProtectSmart helps protect your data from accidental bumps and bruises.
HP SimplePass: Access online accounts with a single password or PIN.
