HP Color LaserJet Enterprise CP4020/CP4520 - Product specifications
Product dimensions
Product dimensions, with toner cartridge
Height
Depth
Width
CP4025n
420 mm
522 mm
540 mm
38.5  kg
CP4025dn
420 mm
522 mm
540 mm
38.5  kg
CP4525n
420 mm
522 mm
540 mm
38.5  kg
CP4525dn
420 mm
522 mm
540 mm
38.5  kg
CP4525xh
964 mm
651 mm
662 mm
64.1  kg
Product dimensions with all doors, trays, and document feeder fully opened
Height
Depth
Width
CP4025n
420 mm
522 mm
765 mm
CP4025dn
420 mm
522 mm
765 mm
CP4525n
420 mm
522 mm
765 mm
CP4525dn
420 mm
522 mm
765 mm
CP4525xh
964 mm
651 mm
866 mm
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2, 3
Product Series4
Printing
Ready
Sleep
Off
HP Color LaserJet CP4025
HP Color LaserJet CP4525
740 W
72 W
19 W
0.3 W
1Values subject to change.
2Power reported is highest value measured for all product models using standard voltages.
3Default time from Ready mode to Sleep = 30 minutes
4HP Color LaserJet CP4025 speed is 35 ppm A4 size and 35 ppm Letter-size.
HP Color LaserJet CP4525 speed is 40 ppm A4 size and 42 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 8.5 A
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 4.5 A
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP Color LaserJet Enterprise CP4020/CP45201
Sound power level
Printing (40 ppm)
Ready
Declared per ISO 9296
LWAd = 6.9 Bels (A) [69 dB(A)]
LWAd = 5.0 Bels (A) [50 dB(A)]
Sound pressure level - Bystander position
Printing (40 ppm)
Ready
LpAm = 54 dB(A)
LpAm = 35 dB(A)
1Acoustic values are subject to change. Configuration tested: HP Color LaserJet CP4525, printing on A4-size paper at 40 ppm in simplex mode.
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17° to 27°C
10° to 30°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3000 m
