    Fix HP Printer issue on macOS
HP Designjet T2500 eMultifunctional Printer Series - Printer specifications
Functional specifications
HP 727 ink supplies
Printhead
One printhead, with doubled nozzles for matte black
Ink cartridges
Cartridges containing 40 ml of ink: gray, photo black, matte black, yellow, magenta, and cyan
Cartridges containing 130 ml of ink: gray, photo black, matte black, yellow, magenta, and cyan
Paper sizes
Minimum
Maximum
Roll width
279 mm
914 mm
Roll length
91 m
Roll diameter
140 mm
Roll weight
11.9 kg
Sheet width
210 mm
914 mm
Sheet length
279 mm
1676 mm
Sheet width (scanner)
914 mm (36 in)
Sheet length (scanner)
15 m (49.21 ft) at 200dpi, TIFF file format and 24 in width
Roll paper thickness
0.5 mm
Sheet paper thickness
0.5 mm
Paper weight
60 g/m²
328 g/m²
* up to 0.6 mm printed to the output stacking tray with manual mode
Printing resolutions
Print quality
Maximum detail
Graphic language
Rendering resolution (ppi)
Printing resolution (dpi)
Best (photo paper*)
On
HP-GL/2, HP PCL3GUI
1200 × 1200
2400 × 1200
PostScript
600 × 600
2400 × 1200
Off
any
600 × 600
1200 × 1200
Best (other papers)
Off
any
600 × 600
1200 × 1200
Normal
Off
HP-GL/2
600 × 600
1200 × 1200
HP PCL3GUI, PostScript
300 × 300
1200 × 1200
Fast (heavyweight coated, photo)
Off
HP-GL/2
600 × 600
1200 × 1200
300 × 300
1200 × 1200
Fast (plain, coated, natural tracing paper)
Off
HP-GL/2
600 × 600
600 × 1200
300 × 300
600 × 1200
Economode
Off
any
300 × 300
600 × 1200
* For a list of supported papers, see Order paperOrder paper.
Scanner resolutions: 200, 300, 600 ppi.
Margins
Top, right and left margins
5 mm
Bottom margin (trailing edge)
5 mm (roll)
22 mm (sheet)
Mechanical accuracy
±0.1% of the specified vector length or ±0.2 mm (whichever is greater) at 23°C,  50-60% relative humidity, on E/A0 printing material in Best or Normal mode with HP Matte Film roll feed.
Graphic languages supported
HP Designjet
Languages
T2500
HP PCL3GUI, HP-GL/2 and HP RTL, CALS G4, TIFF, JPEG, URF
T2500 PS
HP PCL3GUI, HP-GL/2 and HP RTL, CALS G4, TIFF, JPEG, URF, Adobe PDF 1.7, Adobe PostScript 3
Scanner
TIFF, JPEG, PDF
Physical specifications
Printer physical specifications
109 kg
Width
1399 mm
Depth
916 mm (stacker and basket open)
693 mm (stacker and basket closed)
Height
1110 mm (stacker and front panel deployed)
950 mm (stacker and front panel folded)
Memory specifications
HP Designjet
Physical DRAM
Virtual file-processing memory
Hard disk
T2500 series
1.5 GB
128 GB
320 GB
Power specifications
Printer power specifications
Source
100–240 V ac ±10%, auto-ranging
Frequency
50–60 Hz
Current
< 4.2 A
Consumption
< 330 W
Environmental specifications
Printer environmental specifications
Operating temperature
5 to 40°C
Recommended operating temperature
15 to 35°C, depending on paper type
Storage temperature
–25 to 55°C
Recommended operating humidity
20 to 80% RH, depending on paper type
Storage humidity
0 to 95% RH
Acoustic specifications
Printer acoustic specifications (declared according to ISO 9296).
The printer is…
Sound power level B(A)
Sound pressure level dB(A)
Sleeping
< 1.9
16
Ready
5.8
39.2
Printing
6.5
46.9
