Model name
M855dn
A2W77A
M855xh
A2W78A
M855x+
A2W79A
M855x+
D7P73A
Paper handling
Tray 1 (100-sheet capacity)
Tray 2 (500-sheet capacity)
3x500-sheet paper feeder
note: |
3,500-sheet high-capacity input trays
note: |
Automatic duplex printing
Optional 1x500-sheet feeder with cabinet. Available in Europe, the Middle East, Africa, and Asia-Pacific Countries/Regions
note: |
Optional stapler/stacker finishing accessory
Optional stapler/stacker with 2/4 hole punch finishing accessory
Optional booklet maker finishing accessory
Optional booklet maker with 2/3 hole punch finishing accessory
Available in North America and Latin America
Optional booklet maker with 2/4 hole punch finishing accessory
Connectivity
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Easy-access USB port for printing without a computer and upgrading the firmware
HP near-field communications (NFC) and Wireless Direct accessory for printing from mobile devices
Optional HP NFC and Wireless Direct accessory for printing from mobile devices
Storage
HP High-Performance Secure Hard Disk
Control-panel display and input
Touchscreen control panel
Print
Prints 46 pages per minute (ppm) on A4 and 45 ppm on letter-size paper
Easy-access USB printing (no computer required)
Mobile printing solutions
For more information about Mobile printing solutions see:
www.hp.com/go/LaserJetMobilePrinting (English only)
Supported operating systems2,3
Windows XP SP3 or later, 32-bit and 64-bit
note: note: |
Windows Vista, 32-bit and 64-bit
note: |
Windows 7 SP1 or later, 32-bit and 64-bit
Windows 8, 32-bit and 64-bit
Windows 2003 Server SP2 or later, 32-bit and 64-bit
note: note: |
Windows Server 2008, 32-bit and 64-bit
Windows Server 2008 R2, 64-bit
Windows Server 2012, 64-bit
Mac OS X 10.6, 10.7 Lion, and 10.8 Mountain Lion
1The HP ePrint Software supports the following operating systems: Windows® XP SP3 or greater (32-bit) up to ePrint Software version 3; Windows Vista® (32-bit and 64-bit); Windows 7 SP 1 or later (32-bit and 64-bit); Windows 8 (32-bit and 64-bit); and Mac OS X versions 10.6, 10.7 Lion, and 10.8 Mountain Lion.
2The list of supported operating systems applies to the Windows PCL 6, UPD PCL 6, UPD PCL 5, UPD PS, and Mac print drivers and to the in-box software installation CD. For a current list of supported operating systems, go to www.hp.com/support/colorljM855 for HP's all-inclusive help for your product. If you are located outside the US, go to www.hp.com/support, select a country/region, and then click Drivers & Software. Enter a product name or number. In the Download Options area, click Drivers, Software & Firmware. Click the operating system version, and then click the Download button.
3The HP Software Installer CD installs the HP PCL 6 discrete driver for Windows operating systems along with other optional software. Mac installer software is not included on the CD. The CD provides steps to download the Mac installer software from www.hp.com. The steps to download the Mac installer software are as follows: Go to www.hp.com/support, select the country/region, and then click Drivers & Software. Enter a product name or number. In the Download Options area, click Drivers, Software & Firmware. Click the operating system version, and then click the Download button.
