    Apache Log4j Update
HP t620 Flexible Thin Client Product Specifications
Product image
Product features
Feature
Processor
  • AMD GX-217GA Dual-Core APU with AMD Radeon HD 8280E graphics (1.65 GHz)
  • AMD GX-415GA Quad-Core APU with AMD Radeon HD 8330E (1.5 GHz)
Storage
16-64GB MLC mSATA SSD
Memory
  • System memory: 4 GB DDR3L 1600 MHz standard, up to 16 GB
  • Flash memory: 16 GB for configurations using HP ThinPro, HP Smart Zero Technology, and Microsoft Windows Embedded Standard 7E
Graphics
  • Integrated AMD GX-217GA Dual-Core APU with AMD Radeon HD 8280E graphics (1.65 GHz)
Communication
  • 10/100/1000 Gigabit Ethernet (RJ-45) (actual speeds may vary)
  • Broadcom 802.11 a/b/g/n Wi-Fi with dual internal antennas (optional)
  • Broadcom 802.11ac with dual internal antennas (optional)
  • HP 100 Mbps Mini PCIe SC Fiber NIC (factory-installed option)
Audio
  • Internal amplified speaker
  • 1/8-inch mini jack out
  • Full 24-bit stereo
  • Up to 192kHz sample rate
  • 1/8-inch mini jack microphone in
  • 24-bit stereo
  • up to 192 kHz sample rate input audio line in and out connectors on rear panel.
Ports and connectors
  • Front:
    • 2 USB 2.0
    • 2 USB 3.0
    • 1 Headphone
    • 1 Microphone
  • Rear:
    • 2 USB 2.0
    • 2 DisplayPort 1.2
    • 1 RJ45
    • 1 Audio Line-in
    • 1 Audio Line-Out
    • 1PS/2 KB
    • 1 PS/2 Mouse
    • 1 Configurable Port= 1 Serial (Default) or Fiber NIC or VGA
    • Hidden: 2 USB 2.0
Power
65W worldwide auto-sensing 100-240 VAC 50-60Hz surge-tolerant power supply
Input devices
  • Standard keyboard
  • Optical mouse included (USB or PS/2)
Audio/Video
Output
  • 1/8-inch stereo mini jack (headphones, on front panel)
  • 1/8-inch stereo mini jack (line out, on rear panel)
  • Up to 192 kHz sample rate
Input
  • 1/8-inch mini jack microphone (on front panel)
  • 1/8-inch stereo mini jack (line in, on rear panel)
  • 24-bit stereo
Audio CODECS with hardware acceleration support
  • MP3
  • AAC stereo & HE AAC
  • WMA stereo
Video CODECS with hardware acceleration support
  • MPEG-4 part 2 (DivX, Xvid)
  • MPEG-4 part 10 (H.264, AVC)
  • WMV 7/8/9/ VC-1 & ASF Demuxer
Memory
ThinPro
WES 7E
WES 7P
WES 8
Flash (boot drive) SSD
16GB
16GB
16GB
16GB
16GB
Standard system memory
4GB
4GB
4GB
4GB
4GB
System memory reserved for graphics (minimum)
512MB
Maximum system memory (memory speed is 1600 MHz)
16GB DDR3L 1600 MHz (8GB x 2)
4GB DDR3L 1600 MHz (4GB x 1)
Memory slots
2 SODIMMs
Networking
Connector
RJ-45
Data rates supported
  • 10Gb
  • 100Gb
  • 1000Gb
Management
  • Wake on LAN (WOL)
  • PXE
  • TCP/IP with DNS and DHCP
HP Fast Ethernet Mini PCIe SC Fiber Network Interface Card (factory-installed option)
Adapter
Allied Telesis AT-27MINI Fast Ethernet Fiber PCI Express MINI Network Interface Card
Form factor
Custom-designed card plugs into PCI-Express Mini Card slot, and mounts into device bay inside HP t620 chassis
Management features
  • WMI
  • ACPI 2.0/w01
  • PXE 2.1 boot ROM
  • SNMP
Ethernet
  • IEEE 802.1p (Quality of Service)
  • IEEE 802.2 (LLC)
  • IEEE 802.3ac (MAC)
  • IEEE 802.3u (100Mbps)
  • IEEE 802.1as (Audio Bridging)
  • P802.1Qav
  • P802.1Qat (SRP)
  • 1588-2000 (PTP)
Network controller
Broadcom BCM57762
Connectors
SC
Power consumption
2 W(typical)
Compliance
  • RoHS
  • UL
  • FCC/EN55022 Class A
  • TUV
  • EN55024
  • CE
  • C-TICK
  • VCCI
Energy consumption
115 V ac (60 Hz)
230 V ac (50 Hz)
100 V ac (60 Hz)
Standard models (dual core)1
Idle state
4.4236 W
4.5105 W
4.4132 W
Sleep state
0.6241 W
0.6653 W
0.6153 W
Off mode
0.4825 W
0.5287 W
0.4811 W
Standard models (quad core)2
Idle state
4.9246 W
4.993 W
4.9151 W
Sleep state
0.5738 W
0.6337 W
0.5747 W
Off mode
0.4153 W
0.4601 W
0.4132 W
1: Standard models (dual core): slim 15 W 2C, 4G RAM, 32G mSATA, WES 7E.
2: Standard models (quad core): slim 15 W 4C, 4G RAM, 32G mSATA, WES 7E.
Power specifications
Efficiency
65 W
Voltage range
Worldwide auto-sensing 100 - 240 V ac
Line frequency
50 - 60 Hz
Physical specifications
Standard chassis vertical orientation with stand (H x W x D)
240 x 220 x 40 mm (9.5 x 8.7 x 1.6 in)
Standard chassis with stand
1.36 kg (3 lb)
Software/OS
Feature
Operating system preinstalled1
  • HP ThinPro
  • HP Smart Zero Technology
  • Microsoft Windows Embedded Standard 7E
Environmental specifications
Temperature range
  • Operating:
    • Standard: 10°C to 40°C (50°F to 104°F)
    • Using Quick Release with a flat panel monitor: 10°C to 35°C (50°F to 95°F)
    • Using PCIe Expansion Card: 10°C to 40°C (50°F to 104°F)
    • Standard chassis with Fiber NIC: 10°C to 35°C (50°F to 95°F)
  • Non-operating: -30°C to 60°C (-22°F to 140°F)
Humidity
  • Condensing: 20% to 80%
  • Non-condensing: 10% to 90% non-condensing
Specifications are at sea level with altitude de-rating of 1° C/300m (1.8° F/1000ft) to a maximum of 3 Km (10,000 ft), with no direct, sustained sunlight. Upper limit may be limited by the type and number of options installed.
Regulatory compliance
Ergonomics
Approved
Safety
  • UL 1950
  • CSA 950
  • TÜV-GS (EN60 950)
  • Approved
RF interference
  • FCC Class B
  • CE Mark
  • EN55022B
  • VCCI
Eco-Label Certifications & declarations
  • ENERGY STAR
  • EPEAT
  • Models using the factory-installed HP 100 Mbps Mini PCIe Fiber NIC may not meet ENERGY STAR or EPEAT requirements.1
1: Only true for Linux SKUs. WES7E SKUs pass with Fiber NIC
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
