HP Pavilion TouchSmart 15-n011nr Notebook PC Product Specifications
Product Name
15-n011nr
Product Number
F0G95UA
1.6GHz 4th generation Intel Core i5-4200U Processor with Turbo Boost up to 2.6GHz
Microprocessor Cache
1MB L2 Cache
Memory
4GB DDR3L SDRAM (1 DIMM)
Memory Slots
2 user accessible
Video Graphics
Intel HD Graphics 4400
13.3-inch diagonal HD LED- backlit IPS touchscreen display (1366 x 768)
Hard Drive
500GB 5400RPM hard drive with HP ProtectSmart Hard Drive Protection
Multimedia Drive
SuperMulti DVD burner
Network Card
10/100BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity
1x1 802.11b/g/n WLAN
Sound
DTS Sound+
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing Device
Touchpad supporting multi-touch gestures without on/off button
External Ports
Multi-format digital media card reader for Secure Digital cards
2 SuperSpeed USB 3.0
1 Universal Serial Bus (USB) 2.0
1 HDMI
1 RJ-45 (LAN)
1 Headphone-out/microphone-in combo jack
Dimensions
0.97 in (H) x 15.18 in (W) x 10.16 in (D)
5.67 lb
Power
65W AC adapter
4-cell 41WHr 2.8Ah lithium-ion battery
ID Mech Description
Front facing HP TrueVision HD Webcam with integrated dual array digital microphone
Operating System:
Windows 8 (64-bit)
Communication Chat:
Skype
Cyberlink YouCam DE: Chat live and capture video or photos. Be yourself or a favorite avatar!
HP Help Support:
Getting Started with Windows 8: HP’s application makes it fun & easy to get to know Windows 8. Let us help you learn the basics of navigating the new Start Screen, powering off your device, and additional tips and tricks through helpful step by step videos.
HP CoolSense technology adjusts its temperature based on usage and conditions. It stays cool. You stay comfortable.
HP Utility Center: With the HP Utility Center on Windows 8 PCs, get one place to control your settings for all things HP.
Books, Music, Photos, and Videos:
CyberLink Media Suite
CyberLink Power2Go
CyberLink LabelPrint
Productivity Tools:
HP Recovery Manager: Recover, restore, and create recovery media for your PC.
Buy Office 365: The most powerful Office yet with smarter versions of your favorite applications and new cloud services that connect you to your documents and settings – when and where you need them.
Security Protection:
HP ProtectSmart helps protect your data from accidental bumps and bruises.
