HP Deskjet 3520 Printers - Black Ink Not Printing and other Print Quality Issues
This document is for HP Deskjet 3520, 3521, 3522, 3524, 3526, and Deskjet Ink Advantage 3525 e-All-in-One printers.
The quality of a printed document or photo is not as expected. The procedures in this document should help with streaked or faded printouts, color or black ink not printing, documents with blurred or fuzzy text, ink streaks or smears, and other print quality problems.
HP recommends that you use genuine HP ink or toner supplies. HP cannot guarantee the quality or reliability of non-HP or refilled cartridges. If you do not use genuine HP cartridges, the steps in this document might not resolve the issue. To check the authenticity of your cartridges, go to the HP anti-counterfeit webpage (in English).
Solution 2: Allow automatic servicing to complete
Your HP printer has an automatic servicing routine that can solve many print quality issues. There is nothing you need to do. The print quality should improve a few hours after you experience the issue.
If you cannot wait for the automatic servicing routine to complete, continue with the following troubleshooting steps.
Solution 3: Check the paper
Use the following guidelines to make sure that the paper you are using is appropriate for the print job. If it is not, reload the printer with an appropriate paper type.
  • Load the paper print side down in the input tray. Many papers have printing and nonprinting sides, like photo paper and other special media. Usually, the smoother side is the "print side," and sometimes the non-print side has a logo of the paper manufacturer on it.
  • Do not use wrinkled or curled paper. Load only clean, wrinkle-free paper into the product.
    Do not use wrinkled paper
  • Use the correct paper type for your project.
    • For everyday text documents, plain paper with ColorLok technology works well. Paper with ColorLok technology is industry-standard paper that works well with HP ink.
      ColorLok logo
    • For documents with dense printing, such as high contrast graphics or photographs, use HP Advanced Photo Paper for the best results.
    • Some media may not absorb ink as well as others. If your prints smear easily, make sure you are using a recommended paper.
  • Store photo paper in its original packaging inside a resealable plastic bag. Store the paper on a flat surface in a cool, dry place. Load 10-20 sheets of photo paper only when you are ready to print, and then put the unused paper back in the packaging.
  • Try using a different paper. This determines if the problem is related to the paper.
Inappropriate paper usually causes vertical streaks in printouts (or if the problem occurs on a copy, dirty scanner glass usually causes the issue). Do not replace ink cartridges to fix vertical streaks.
Examples of horizontal streaks and vertical streaks in printout
Figure : Horizontal streaks in printout
Image of horizontal streaks
Continue with the following troubleshooting steps if your printout contains horizontal streaks, or other print quality issues besides vertical streaks.
Figure : Vertical streaks in printout
Image of vertical streaks
Do not replace ink cartridges for vertical streaks in a printout. Instead, check the paper as described earlier in this document, or search for a document that covers this issue.
Try printing again after trying the preceding guidelines.
Solution 4: Check the print settings
Follow these steps to check the print settings to make sure that they are appropriate for your print job.
Solution 5: Check ink levels, and then replace low or empty ink cartridges
Follow these steps to check the estimated ink levels on your printer, and then replace low or empty ink cartridges according to the results.
Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement ink cartridge available to avoid possible printing delays. You do not need to replace ink cartridges until print quality becomes unacceptable.
On the printer control panel, press the down arrow to select Ink Levels, and then press OK.
The Ink Levels screen displays with gauges for all four ink colors.
Solution 6: Print and evaluate a print quality report and troubleshoot defects
Follow these steps to print, and then evaluate a print quality report.
Step 1: Print a print quality report
  1. Load plain, white paper into the paper tray.
  2. On the printer control panel, press the down arrow to select Settings, and then press OK.
  3. Press the down arrow to select Tools, and then press OK.
  4. Press the down arrow to select Print Quality Report, and then press OK.
    The report prints.
    Figure : Example of a print quality report
    Image of a print quality report.
Step 2: Check the print quality report for defects
In general, if the printer and its ink cartridges are working correctly, all the color bars should be present, unstreaked, and uniform in color across the width of the report. The black text on the report should not show ink streaks.
Review this table for examples of defects that can exist on the report. These examples are not inclusive, but tend to represent the most common issues.
Examples of defects on a print quality report
Defect
Example
Large font text is ragged on one end
Image of ragged large text
Irregularly streaked or faded color bars
Image of streaked or faded color bars
Ragged color bars
Image of ragged color bars
The color bars are streaked with another color
Image of streaked color bars
The color blocks have regular white streaks
Image of white streaks in the color bars
Jagged alignment patterns
Image of jagged alignment patterns
  • If you see no defects on the report, the print mechanism and ink supplies work correctly. If printouts are still unsatisfactory, try these general print quality guidelines, and then do not continue the troubleshooting steps in the remainder of this document:
    • Make sure that the image you are printing has sufficient resolution. Images that are enlarged too much might appear fuzzy or blurry.
    • If the problem is confined to a band near the edge of a printout, use the software you installed with the printer, or another software program to rotate the image 180°. The problem might not appear on the other end of the printout.
  • If you see one or more of these defects on the report, continue to the next step.
Step 3: Make sure that the ink cartridges are properly vented
  1. Grasp the handles on either side of the ink cartridge access door, and then raise the door until it locks into place.
    The carriage moves to the access area.
    Figure : Open the ink cartridge access door
    Image: Open the ink cartridge access door.
  2. Press the tab on the front of the ink cartridge inward to release it, and then pull up on the ink cartridge to remove it from the slot.
    • If the error message mentions a specific ink cartridge, locate that ink cartridge, remove it from the carriage, and then continue with the next step.
    • If the error message does not mention a specific ink cartridge, remove all the ink cartridges, one at a time, and then continue with the next step.
    Figure : Remove the ink cartridge
    Image: Remove the ink cartridge.
  3. Examine the vent area on each ink cartridge, above the HP logo on the top of the ink cartridge.
    Figure : Vent area
    Image of the ink cartridge vent area.
  4. If the ink cartridge still has the orange pull-tab attached, pull to remove it.
    Figure : Orange pull tab
    Image: Orange pull tab.
  5. If the vent is clogged, use a straight pin to gently remove excess adhesive from the vent.
      Figure : Clean the clogged vent with a pin
      Image: Clean the clogged vent with a pin.
    1. Clogged vent
    2. With a straight pin, gently remove excess adhesive from the vent
    3. Unclogged vent
  6. With the nozzle and the contacts facing down, push the ink cartridge into its slot. Press down on the ink cartridge until it clicks into place. Make sure that the color icon on the ink cartridge label matches the color icon on the slot.
    Make sure that each ink cartridge is installed in the correct slot. Match the shape of the icon and the color of the ink cartridge with the slot that has the same shaped icon and color.
    Figure : Insert the ink cartridge
    Image: Insert the ink cartridge.
  7. Repeat these steps to inspect the vents on each of the ink cartridges.
  8. Make sure that each ink cartridge is firmly in place in its slot. Run your finger along the top of the ink cartridges to feel for any that are protruding, and if any are, press down firmly until each ink cartridge snaps into place.
  9. Close the ink cartridge access door.
    Figure : Close the ink cartridge access door
    Image: Close the ink cartridge access door.
  10. Try the print job again.
Step 4: Clean the printhead automatically
Follow these steps to run an automatic utility to clean the printhead.
Never turn off the printer when ink cartridges are not installed. To avoid issues that require cleaning the printhead or that can damage the ink system, always replace ink cartridges as soon as possible, and always turn off the printer using the Power button.
  4. Press the down arrow to select Clean Printhead, and then press OK.
    The printer cleans the printhead, and then prints a test page.
  5. Review the print quality on the test page.
    • If these steps resolved the issue, there is no need to continue troubleshooting.
    • If the issue persists, continue to the next step.
Step 5: Align the printhead
Use the Align Printer tool on the printer control panel to align the printhead.
  1. Load letter or A4, unused, plain white paper into the paper tray.
  2. On the product control panel, press the Down Arrow () to select Settings, and then press OK.
  3. Press the Down Arrow () to select Tools, and then press OK.
  4. Press the Down Arrow () to select Align Printer, and then press OK. The product prints an alignment page.
  5. Open the lid.
    Figure : Open the lid
    Image: Open  the lid.
  6. Place the alignment page on the scanner glass with the printed side down, and then position it on the front right corner of the glass.
    Figure : Place the alignment page on the scanner glass
    Image: Place the alignment page on the scanner glass.
  7. Close the lid, and then press OK. The product scans the alignment page.
  8. Follow the control panel instructions to complete the alignment.
  9. Recycle or discard the alignment page.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Solution 7: Replace the problem ink cartridges
If none of the preceding steps resolves the issue, replace the ink cartridge that corresponds to the defect on the print quality report. For example, if one of the magenta color bars is defective, replace the magenta ink cartridge. Use the following steps to replace the problem ink cartridge.
If you have a defective cartridge or printhead, it might be under warranty. To check the warranty on your ink or toner supplies, go to hp.com/go/learnaboutsupplies, and then review the limited warranty information for your supplies.
Step 1: Replace the problem ink cartridge
Replace the ink cartridge that is causing the issue.
The following video demonstrates how to replace an ink cartridge.
This video shows the HP Deskjet 3520 e-All-in-One printer, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
  1. Turn on the printer, if it is not already on.
  3. Grasp the handles on either side of the ink cartridge access door, and then raise the door until it locks into place.
    Figure : Opening the ink cartridge access door
  4. Press the tab on the front of the ink cartridge inward to release it, and then pull up on the ink cartridge to remove it from its slot.
    Replace missing ink cartridges promptly.
    Figure : Removing the ink cartridge
  5. Pull the orange tab to remove the plastic wrap from the new ink cartridge.
    Figure : Removing the plastic wrap from the new ink cartridge
    Make sure you remove the orange pull-tab and plastic wrap completely before you twist the orange cap in the next step. Otherwise, ink might leak from the ink cartridge. When you remove the plastic wrap, the paper label on the top of the ink cartridge tears slightly, which is necessary to properly vent the ink cartridge.
  6. Twist the orange cap counter-clockwise until it snaps off.
    Figure : Removing the orange cap from the ink cartridge
  7. With the nozzle and the contacts facing down, insert the ink cartridge into its color-coded slot. Press down on the ink cartridge until it snaps into place.
    Figure : Inserting the ink cartridge
  8. Repeat these steps to replace any other ink cartridges.
    Figure : Closing the ink cartridge access door
Step 2: Align the printer
After you load new ink cartridges and close the ink cartridge access door, the printer automatically prompts you to print an alignment page. Follow these steps to align the ink cartridges.
  2. On the printer control panel, press OK.
    The printer prints an alignment page.
  3. Open the scanner lid.
    Figure : Opening the scanner lid
  4. Place the alignment page with the print side down on the scanner glass, and then position it according to the engraved guides around the glass.
    Figure : Placing the alignment page on the scanner glass
  5. Close the lid, and then press OK.
    The printer scans the alignment page.
  6. Follow the control panel instructions to complete the alignment.
Keep a print sample that shows the problem. If the ink cartridges, printhead, or printer is replaced under warranty, the support agent will request the print sample. If the printer is returned to HP, the print sample must be returned with the printer. Place the sample in the output tray when you package your printer for shipping.
