HP LaserJet Enterprise flow MFP M830 - Replace the toner cartridge
Continue printing with the current cartridge until redistributing the toner no longer yields acceptable print quality. To redistribute the toner, remove the toner cartridge from the printer and gently rock the cartridge back and forth about its horizontal axis. For graphical representation, see cartridge replacement instructions. Reinsert the toner cartridge into the printer and close the cover.
Toner cartridge part number: CF325X
The following illustration shows the toner-cartridge components.
    Figure : Toner cartridge components, back view
  1. Imaging drum (Do not touch the green roller. Doing so can damage the cartridge.)
  2. Memory chip
If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
Information about recycling used toner cartridges is on the toner cartridge box.
  1. Open the front door. Make sure that the door is completely open.
    Figure : Open the door
  2. Push the button on the lever, and then rotate the toner-cartridge lever to the down position.
    Figure : Release the toner-cartridge lever
  3. Grasp the handle of the used toner cartridge and pull out to remove it.
    Figure : Remove the toner cartridge
  4. Remove the new toner cartridge from its protective bag.
    Figure : New toner cartridge
  5. Hold both ends of the toner cartridge and rock it 5-6 times.
    Figure : Rock the toner cartridge
  6. Align the toner cartridge with its slot, and then insert the toner cartridge into the product. The toner cartridge will drop slightly when it is in place.
    Figure : Install the toner cartridge
  7. Push the button on the lever, and then rotate the toner-cartridge lever to the up position.
    Figure : Lock the toner-cartridge lever
  8. Close the front door.
    Figure : Close the door
