    Fix HP Printer issue on macOS
HP LaserJet Pro MFP M435nw - Replace the toner cartridge
When a toner cartridge approaches the end of useful life, you are prompted to order a replacement. You can continue printing with the current cartridge until redistributing the toner no longer yields acceptable print quality.
Continue printing with the current cartridge until redistributing the toner no longer yields acceptable print quality. To redistribute the toner, remove the toner cartridge from the printer and gently rock the cartridge back and forth about its horizontal axis. For graphical representation, see cartridge replacement instructions. Reinsert the toner cartridge into the printer and close the cover.
The following illustration shows the toner-cartridge components.
    Figure : Toner-cartridge components
  1. Imaging drum (Be careful not to touch the imaging drum.)
  2. Memory chip
  3. Sealing tape
  1. Open the front door.
    Figure : Open the front door
  2. Remove the used toner cartridge.
    Figure : Remove the toner cartridge
  3. Remove the new toner cartridge from the bag. Place the used toner cartridge in the bag for recycling.
    Figure : Remove the new toner cartridge from the package
  4. Grasp both sides of the toner cartridge and distribute the toner by gently rocking the cartridge.
    Do not touch the imaging drum.
    Figure : Gently rock the toner cartridge
  5. Remove the sealing tape. Bend the tab on the left side of the cartridge until the tab breaks loose. Pull the tab until all the tape is removed from the cartridge. Place the tab and tape in the toner-cartridge box to return for recycling.
    Figure : Remove the sealing tape
  6. Align the toner cartridge with the tracks inside the product, insert the toner cartridge until it is firmly seated.
    Figure : Insert the toner cartridge
  7. Close the front door.
    Figure : Close the front door
