    We are upgrading our website
HP K4000 Bluetooth Keyboard - Setting up the Bluetooth Keyboard
This document applies to setting up the HP K4000 Slim Bluetooth Keyboard.
Figure : HP K4000 Slim Bluetooth Keyboard
Contents and components
The keyboard includes the following:
  • Slim Bluetooth Keyboard with:
    • Pairing button
    • On/off power button
    • Battery compartment
      Figure : HP K4000 Slim Bluetooth Keyboard controls
    1. Pairing button
    2. Power button
    3. Battery compartment
  • 2 AAA Batteries
  • Quick Setup poster
Step 1: Inserting batteries
Insert 2 AAA alkaline batteries in the battery compartment, accessed from the rear panel.
Battery compartment
Step 2: Power on
Power on the HP computer, and then power on the Slim Bluetooth Keyboard by sliding the power switch to its power-on position.
Power switch
You must have Bluetooth wireless technology installed on your computer to complete this procedure.
Step 3: Preparing to pair the Bluetooth keyboard with your computer
Before pairing the Slim Bluetooth Keyboard with an HP computer, ensure that the computer has Bluetooth in Discovery mode:
For Windows 7:
  1. Right-click the Bluetooth icon in the notification area, at the far right of the taskbar, and then click Open Settings.
  2. In the Options tab, click the box under Discovery to Allow Bluetooth devices to find this computer.
  3. Click Apply, and then click OK.
For Windows 8:
  1. From the Windows 8 Desktop screen, select the Bluetooth icon in the notification area, at the far right of the taskbar, and then click Open Settings.
Step 4: Pairing the HP K4000 Bluetooth Keyboard with your computer
To pair the Slim Bluetooth Keyboard with an HP computer:
  1. Press and hold the pairing button for three seconds.
    Pairing button
  2. If you are using Windows 7, right-click the Bluetooth icon in the notification area, at the far right of the taskbar, and then click Add a device.
    If you are using Windows 8, from the Windows Start screen, swipe from the right edge of the touch screen (if you are using a mouse, point to the upper-right corner of the screen) to display the charms, and select Settings > Change PC settings > Devices > Add a device.
  3. Select HP Slim Bluetooth Keyboard from the list of devices displayed in the Add a device window.
  4. Use the Bluetooth Keyboard to type the variable PIN code displayed in the next window, and then press Enter.
Country: Flag Vietnam
