HP EliteDisplay E221c 21.5-inch Webcam LED Backlit Monitor - Overview
Product description
Product features
Feature
Model
D9E49AA
Panel type
IPS with LED backlight
Viewable image area
54,6 cm (21.5-inch) diagonally measured
Viewing angle
  • Horizontal: 178°
  • Vertical: 178°
Brightness
250 cd/m
Contrast ratio
  • Static: 1000:1
  • Dynamic: 5,000,000:1
Frequency
  • Horizontal: 24 KHz - 94 KHz
  • Vertical: 50 Hz - 76 Hz
Aspect ratio
16:9
Native resolution
1920 x 1080 @ 60 Hz
Input signal
VGA (analog), DVI-D, DisplayPort (HDCP support on DVI-D and DisplayPort)
USB
Integrated USB 2.0 hub with (2) Downstream and (1) Upstream ports
Audio
1-W channel built-in speakers (rear firing); PC audio in, headphone/speaker audio out
Integrated 720p webcam with dual microphones
Base features
  • Tilt: -5 to +30 degrees
  • Swivel: 360°
  • Height adjustable: 150 mm
  • Pivot rotation: 90°
Software overview
Feature
Featured software
  • HP Display Assistant
  • Cyberlink You Cam
  • HP MyRoom
