Setting Up the Printer Hardware for HP Color LaserJet Pro M177fw MFP Printers
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Step 2: Remove the packaging and prepare the cartridges
Follow these steps to remove all the packaging material from the printer and then prepare the cartridges for printing.
  1. Take the printer out of its box, and then remove the packaging.
    Figure : Unpack the printer
    Image: Unpack the HP printer
  2. Place the printer in a sturdy, well-ventilated, dust-free area, away from direct sunlight.
  3. Remove the protective plastic sheet from the ADF output tray.
    Figure : Remove the protective sheet from the ADF output tray
    Image: Remove the protective sheet.
  4. Lift the scanner assembly, and then remove the tape and protective foam from underneath.
    Figure : Lift the scanner assembly
    Image: Lift the scanner assembly.
  5. Open the cartridge access door, remove the foam insert, and then pull the two orange rings straight up to remove the cartridge sealing tape.
    Image: Open the cartridge access door
    Figure : Remove the foam insert, and then pull the two orange rings straight up
    Image: Remove the foam insert and the orange sealing tape
  6. Hold the left and right corners of the included setup instructions, and then pull straight up to remove them.
    Figure : Pull straight up to remove the setup instructions
    Image: Pull straight up to remove the setup instructions
  7. Recycle or dispose of the packing material.
    Figure : Recycle the packing material
    Image: Recycle the packing material
  8. Attach the input paper tray (bottom), the output paper tray extender (top), and then lower the scanner assembly.
      Figure : Attach the input paper tray, the output paper tray extender, and then lower the scanner assembly
      Image: Attach the input paper tray and the output paper tray extender, then lower the scanner assembly
    1. Attach the input paper tray
    2. Attach the output paper tray extender
    3. Lower the scanner assembly
Step 3: Load paper
Follow these steps to load paper in the paper input tray.
  1. Slide the left and right paper width guides all the way to the outside of the paper tray, and then, if necessary, pull the bottom paper width guide as far away from the printer as possible.
    Figure : Slide the paper width guides outward
    Image: Pull out the paper guides
  2. Load plain white paper into the paper tray.
    Figure : Load paper into the paper tray
    Image: Load paper into the paper tray
  3. If necessary, slide the paper width guides inward so that they rest on the edges of the paper.
    Figure : Slide the paper guides inward
    Image: Slide the paper width guides inward
  4. Place the dust cover on the paper tray.
    Figure : Place the dust cover on the paper tray
    Image: Install the paper tray cover
Step 4: Adjust the control panel display
Gently lift the control panel display into the preferred position.
Figure : Adjust the control panel display
Image: Adjust the control panel display.
Step 5: Connect the power cord and turn on the power
  1. Connect the power cord to the rear of the printer.
  2. Plug the power cord into an electrical outlet.
    Figure : Connect the power cord
    Image: Connect the power cord.
  3. Press the Power button to turn on the printer. The printer initializes and calibrates itself.
    Wait until the printer is idle and silent before proceeding. Do not connect the USB cable yet.
    Figure : Do not connect the USB cable yet
    Image: Do not connect the USB cable yet.
Step 6: Select the language
After the printer finishes calibrating, the language selection menu displays. Follow these steps to select the language displayed on the printer control panel.
  1. If necessary, touch the Down Arrow () to find your desired language in the list.
  2. Touch your desired language, and then touch Yes to confirm the selection.
    If you select the wrong language, touch No, and then touch the correct language.
  3. If necessary, touch the Down Arrow () to find your desired country/region.
  4. Touch your desired country/region, and then touch Yes to confirm the selection.
Link to fax setup instructions
Set up the printer to send and receive faxes
