    Fix HP Printer issue on macOS
Blinking Lights on the HP Deskjet 1510 and Deskjet Ink Advantage 1510 Printer Series
Blinking lights
The following sections describe the most common combinations of blinking (flashing) lights displayed on the control panel, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
    Image: Control panel with lights indicated
  1. Power button
  2. Check color ink cartridge light
  3. Check black ink cartridge light
  4. Attention light
