Document ID: c03841956
Version: 1
HP t510 Flexible Thin Client - Citrix Standard Receiver Cannot Login With Smartcard by Web Interface
Release date : 15-Jul-2013
Last updated : 15-Jul-2013
DESCRIPTION
Citrix Standard Receiver does not logon by smartcard using the web interface or storefront.
SCOPE
Systems:
  • HP t510 Flexible Thin Client
  • HP t610 Flexible Thin Client
  • HP t610 PLUS Flexible Thin Client
Operating Systems:
  • Microsoft Windows Embedded Standard 2009 (WES 2009)
  • Microsoft Windows Embedded Standard 8 (WES 8)
  • Microsoft Windows Embedded Standard 7 (WES 7)
RESOLUTION
Inform the customer that using Citrix Receiver (ver. 3.4.0.29577) to login using a smart card is not supported. Use the following link to upgrade to Citrix Enterprise Receiver ver. 3.4 :
NOTE: One or more of the preceding links will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
Hardware platforms affected : HP t510 Flexible Thin Client, HP t610 Flexible Thin Client, HP t610 PLUS Flexible Thin Client
Support Communication Cross Reference ID : IA03841956
