    We are upgrading our website
Document ID: c03787703
Version: 1
Advisory: HP Compaq 8100 Elite, HP Compaq 8200 Elite - Losing Network Connection When Applications Generate High Network Traffic
Release date : 04-Jun-2013
Last updated : 04-Jun-2013
DESCRIPTION
Systems listed in the "Scope" may intermittently lose network connectivity for 10-15 seconds and then resume. The anomaly can occur when the default amount of memory allocated to either the transmit or receive buffers is not adequate for high data rate transmissions (greater than 100 Mbps) over a Gigabit network. The anomaly has been observed with UDP transmissions, but other protocols could be affected as well.
sourceInformation
SCOPE
Systems:
  • HP Compaq 8100 Elite Convertible Minitower PC
  • HP Compaq 8100 Elite Small Form Factor PC
NIC:
  • using the integrated NIC
RESOLUTION
Resolve the issue by increasing the driver configurable transmit and/or receive buffers:
  1. Increase the Transmit Buffer size to Max (2048). If this resolves the issue, then skip Step 2.
  2. Increase Receive Buffer to Max (2048).
NOTE
Windows 7 and later operating systems dynamically manage the total buffer size configured in the driver. It should not be necessary to look for smaller buffer sizes unless it is desirable to manually limit them. In that case, try incrementally decreasing the buffer sizes to find the optimum favorable configuration.
Warning! Do not use a smaller buffer sizes than the defaults:
Transmit default is 640
Recieve default is 256
Hardware platforms affected : HP Compaq 8100 Elite Small Form Factor PC, HP Compaq 8180 Elite Convertible Microtower PC
Operating systems affected : Microsoft Windows XP Professional Edition
Support Communication Cross Reference ID : IA03787703
Country: Flag Vietnam
