HP LaserJet Enterprise, HP PageWide Enterprise, HP OfficeJet Enterprise - Set custom paper types using the Embedded Web Server or Web Jetadmin
HP Enterprise printers support up to 10 (previously 5) custom paper types also called User Types 1-10. Administrators can define these paper types in either Web Jetadmin or the Embedded Web Server (EWS).
The EWS is typically used to define User types for one printer at a time, while Web Jetadmin is used to define User types for multiple printers at one time.
UPD v5.0 first implemented support for the custom paper type feature User Types 1-5. Product-specific (discrete) drivers, and UPD v5.3.1 (and later), add support for User Types 6-10.
To update the printer’s capabilities and obtain the latest custom paper type features, update the driver to the latest version.
To obtain the latest driver, go to www.hp.com/go/upd, or to obtain the product-specific driver, go to support.hp.com/drivers.
Why custom paper types?
Custom paper types are useful in a shared printer setting where a custom settings are desired without affecting other users of the same printer. Also, pre-defined paper types such as Letterhead have default settings that are optimized for that particular paper type.
To avoid losing the optimal settings for pre-defined types, use custom paper types.
Step one: Define Paper Types
Custom paper types can only be added to the driver by using automatic configuration enabled by bi-directional communication. The custom paper types must already exist in the product when the bi-directional query occurs.
To make sure the custom paper types exist in the printer, define them first in Web Jetadmin or the EWS using the steps below.
Step two: Run the Automatic Configuration
Settings like custom paper types are automatically configured at driver installation within the product-specific (discrete) or Universal Print Driver (UPD) v5.0 (or later) when the bi-directional (bi-di) setting is enabled in the driver, and when the custom paper types (stored in the printer's firmware) are already defined using the Embedded Web Server (EWS) or Web Jetadmin (WJA).
Because network connection is most common for EWS and Web Jetadmin, USB-connection steps are not listed here.
If the driver was installed prior to defining the custom paper types in the EWS/WJA, then follow these steps to run the Automatic Configuration feature using the Update Now option in Printer Properties to query the printer for the custom paper types defined previously.
  1. In Windows, open Devices and Printers.
  2. Select the UPD, and then click Printer Properties in the upper window, or right-click the printer and then click Printer Properties.
  3. Click the Device Settings tab.
  4. Under Installable Options , click the drop-down menu next to Automatic Configuration and select Update Now.
    Figure : Select Update Now in the Automatic Configuration drop-down menu
  5. Click OK.
    This will initiate the bi-directional communication process and can take a few minutes depending on the environment and configuration. When finished, the status will change to Off. If the Automatic Configuration option is grayed out, then bi-directional communication is disabled. Contact the system administrator.
  6. Click the General tab, click Preferences, and then click the Paper/Quality tab to view the paper types.
    User Types 1-10 only appear in the driver after they have been enabled through EWS or Web Jetadmin. If the User Types you defined in EWS or Web Jetadmin are not visible after you update the Automatic Configuration, skip to the Check the bi-di connection section below and follow the steps provided.
  7. Click OK to close the window.
Bi-directional (bi-di) communication between the driver and the printer is possible through a network connection by means of TCP/IP. If you do not see the custom paper types in the list, the bi-di communication process might have failed. Make sure that bi-di communication is working properly between the driver and the printer.
Printer Automatic Configuration can fail due to issues in the communication path, the client or network configuration, or driver settings. Successful bi-directional communication requires that the UPD-installed bi-directional services are loaded, the port settings are correct, and the printer is available over the network.
Follow these steps to check the bi-di connection:
  1. Make sure the printer is connected to the network via TCP/IP.
  2. In Windows, open the Devices and Printers folder.
  3. Right-click the HP UPD, select Printer Properties, click the General tab, and then click Print Test page.
  4. If you can print, try again to run Automatic Configuration (Update Now).
    If you cannot print, click the Port tab and make sure the correct port is selected and that it is configured properly.
    If you are not sure how to do this, or if you still cannot print, contact the system administrator.
  5. Check the network connection method and make sure that the port is defined correctly (TCP/IP address or DNS name).
