HP EliteDisplay E231 23-inch LED Backlit Monitor - Option Parts
New model specific parts lists
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website for this product.
Spare part
Spare Part Number
HP E231-LA2307x 21.5-inch LED Backlit Elite Monitor
713027-001
Option parts
Option Part Number
HP LCD Monitor Quick Release
EM870AA1
HP USB Graphics Adapter
NL571AA
HP Business PC Security Lock Kit
PV606AA
HP LCD Speaker Bar
NQ576AA
HP Integrated Work Center 2 – Small Form Factor (SFF)
QP897AA
HP Single Monitor Arm
BT861AA
HP Adjustable Dual Display Stand
AW664AA
HP DVI to DVI Cable
DC198A
1. The HP Quick Release has been designed to support a maximum of up to 24 lbs (10.9 kg) for all devices mounted. Because mounting surfaces vary widely and the final mounting method and configuration may vary, mounting fasteners are not supplied (other than the VESA-compliant screws). HP recommends that you consult with a qualified engineering, architectural or construction professional to determine the appropriate type and quantity of mounting fasteners required for your application and to ensure that your mounting solution is properly installed to support applied loads.
