HP ENVY 23-c260jp All-in-One PC Product Specifications and Configurable Options
An HP configure-to-order (CTO) PC is a computer that can be purchased with options and components that fit your needs. This document provides specification information about base options and lists which available components were offered for this computer model.
Information in this document is subject to change without notice
Model name and product number
This document contains basic features and specification for the following HP CTO model:
  • HP ENVY: 23-c260jp
  • Product number: D7G10AV
Introduction date
12-May-2013
Included Hardware
Hardware Component
  • 58.42 cm (23 inch) LCD high-definition panel display
    • Resolution: 1920 x 1080 (16:9 aspect ratio)
    • Colors: 16.7 million
    • Color gamut: 72%
    • Response time: 5 ms (typical)
    • Contrast ratio: 1000:1
    • Image brightness: up to 250 nits
Motherboard Name
  • Manufacturer: Pegatron
  • Manufacturer name: IPISB-NK
  • HP: Lavaca3-SB
  • Intel H61
Front-side-bus (processor dependent)
  • DMI (Direct Media Interface)
  • 5 GB/s
Memory
  • Memory slots: 2 SODIMMS (204-pin)
  • Maximum memory:
    • 16 GB (2 x 8 GB)
Integrated Video
  • Integrated Intel HD 2000 graphics (supported by the processor)
Integrated Audio
  • Integrated High Definition Audio
  • Audio CODEC: IDT 92HD91
Integrated LAN
  • Technology: Realtek RTL8111E
  • Data transfer speeds: up to 10/100/1000 Mb/s
  • Transmission standards: 1000-Base-T Ethernet
Expansion Slots
  • PCI Express MXM slot that supports a PCI Express x16 graphics card (Gen 2.0): 1
  • PCI Express x1 minicard socket (Gen 2.0): 2
Media Card Reader
  • 6-in-1 media card reader
  • Integrated 720p low-light webcam with 2 microphone array
Drive Bays
  • 13.33 cm (5.25 inch) ODD: 1
  • 8.89 cm (3.5 inch) HDD: 1
Power output wattage
  • 180 Watt
Hardware Options
Hardware Component
Options
Processor
Must select one of the following options:
  • Core i3-3220 (Ivy Bridge) (65W) 3.3 GHz
  • Core i3-3240 (Ivy Bridge) (65W) 3.4 GHz
  • Core i5-3470s (Ivy Bridge) (65W) 2.9 GHz
  • Core i5-3570s (Ivy Bridge) (65W) 3.1 GHz
  • Core i7-3770s (Ivy Bridge) (65W) 3.1 GHz
Memory
  • 4 GB (1 x 4 GB) DDR3 PC3-12800
  • 8 GB (2 x 4 GB) DDR3 PC3-12800
  • 8 GB (1 x 8 GB) DDR3 PC3-12800
  • 16 GB (2 x 8 GB) DDR3 PC3-12800
Hard Drive
  • 500 GB 7200 RPM SATA
  • 1 TB 7200 RPM SATA
  • 2 TB 7200 RPM SATA
  • 3 TB 7200 RPM SATA
Primary Optical Drive
  • Slot-load SuperMulti DVD Burner
  • Slot-load SuperMulti Blu-ray Player
  • Slot-load SuperMulti Blu-ray Burner
Removable Storage
  • HP 500 GB Pocket Media Drive (USB 3.0)
Networking
  • Integrated Bluetooth 4.0 and Wireless LAN 802.11a/b/g/n featuring Dual-band (2.4GHz and 5GHz) 2x2 MIMO technology
Graphics
  • Integrated Intel HD Graphics
  • GeForce GT 630M (2 GB)
TV Tuner
  • No TV Tuner
  • HP TV Tuner JPN Dual Hybrid mini-card
Scalar Card
  • No Scalar Card
  • Scalar Card with HDMI input
Keyboard and Mouse
  • USB Keyboard with Volume Control and Optical Mouse
  • HP Wireless Keyboard with Volume Control and Wireless Optical Mouse
  • HP Wireless Keyboard with Volume Control and Wireless Optical Mouse + Remote Control
Included Software
Software Category
Options
Digital Media Software
  • CyberLink Media Suite
Connected with HP
  • HP Connected Photo
Security Software
  • Norton Internet Security 2013 (60-day security update subscription)
Software Options
Software Category
Options
Operating System
  • Windows 8 (64-bit)
  • Windows 8 Professional (64-bit)
Productivity Software
  • No Productivity software
  • Microsoft Office Personal 2013
  • Microsoft Office Home and Business 2013
  • Microsoft Office Professional 2013
Entertainment and Utility Software
  • Adobe Premiere + Adobe Photoshop Elements 11
Security Software
  • No additional security software
  • Norton Internet Security 2013 (15 months)
  • Norton Internet Security 2013 (24 months)
HP Care Pack Services
Protect your investment with an HP Care Pack Service. For the latest plans offered, select Services at hpshopping.com.
Country: Flag Vietnam
