Using HP Pocket Playlist with an Apple / Mac OS X Computer
This document pertains to the HP Pocket Playlist with Apple devices.
This is an edited copy from the printed format of the HP Pocket Playlist User Guide. To obtain a better representation of the printed form, refer to the manuals section of this product’s support site.
Using the Pocket Playlist requires that you load software onto your Apple computer, and then use the computer as the hub from which you add content to the Pocket Playlist. See Setting up the HP Pocket Playlist for detailed instructions.
You can configure an Apple computer with the latest OS X operating system to access the folders and configuration screens on the Pocket Playlist.
Supported Devices
The iOS app supports the following devices:
  • iPod touch Gen 3/4/5
  • iPhone 3GS and above
  • iPad (all models)
Apps are available from the Apple App Store that allow optimized playback of the multimedia content.
Accessing the Pocket Playlist configuration screens
To configure the Pocket Playlist, follow these steps:
  1. Open a web browser, such as Safari or Firefox. Make sure the Mac system has a wireless connection to the Pocket Playlist.
  2. In the Location box, enter the IP address or name of the device.
    IP address example: http://10.10.10.254
    Name example: http://PocketPlaylist
    You can find the IP address for the device on your router's configuration screens, usually under DHCP Client Table Devices or Show Connected.
  3. Click Settings to access the configuration/settings screen.
Mapping folders on a Mac
Mapping to the Pocket Playlist is similar to mapping any network drive. Open the Mac, and follow these steps:
  1. In the Finder, click Go, Connect to server.
  2. In the Connect to server dialog box, click Browse.
  3. In the Network window, click WORKGROUP, PocketPlaylist.
  4. In the panel that shows the available shares, click Connect.
  5. In the list on the Shared Volume window, select a shared volume, and then click OK.
  6. In the SMB/CIFS File System Authentication window, enter the password if you have set one up, and then click OK.
Playing media files loaded on the Pocket Playlist
The following steps outline what is required to play media files loaded on your Pocket Playlist on your Apple device:
  1. From your computer, load media files onto the Pocket Playlist.
  2. Go to the app store on your mobile device, search for the Pocket Playlist, and then download and install the mobile application.
  3. Establish a connection from your mobile device to the Pocket Playlist.
  4. Open the app on your mobile device and select your Pocket Playlist.
  5. Navigate to and play media files.
