Document ID: c03747895
Version: 1
HP EliteBook, ProBook Notebook, and mt40 Thin Client PCs - Battery Does Not Charge or Is Not Detected After Completely Draining the Battery
Release date : 26-Apr-2013
Last updated : 26-Apr-2013
DESCRIPTION
The battery does not charge or is not detected after being completely drained. If the battery is detected, it has a 0% power level and displays, "Plugged in - not charging". The LED charging light flashes orange repeatedly. The symptoms may follow the battery if it is inserted into a different computer with the same BIOS version. Inserting a new battery into the affected computer may temporarily resolve the issue, but the symptoms may reoccur if the battery is completely drained of power.
SCOPE
Computers:
  • HP EliteBook 8460p Notebook PC
  • HP EliteBook 8460w Mobile Workstation
  • HP EliteBook 8470p Notebook PC
  • HP EliteBook 8470w Mobile Workstation
  • HP EliteBook 8560p Notebook PC
  • HP EliteBook 8570p Notebook PC
  • HP mt40 Mobile Thin Client
  • HP ProBook 6360b Notebook PC
  • HP ProBook 6460b Notebook PC
  • HP ProBook 6470b Notebook PC
  • HP ProBook 6560b Notebook PC
  • HP ProBook 6570b Notebook PC
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
If the affected computer is in the SCOPE but not in the SoftPaq Affected Models list, contact the appropriate technical support center for your country. Use the following link to find contact information for support centers in your country or region: http://welcome.hp.com/country/us/en/wwcontact.html.
Reference this document when requesting assistance.
Affected Models
SoftPaq Description
Release Notes
Download SoftPaq
HP Elitebook 8570p Notebook PC
HP Notebook System BIOS Update
Version: F.41
Version: F.41
Version: F.05
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP EliteBook 8470p Notebook PC, HP EliteBook 8470w Mobile Workstation, HP EliteBook 8560p Notebook PC, HP EliteBook 8570p Notebook PC, HP ProBook 6360b Notebook PC, HP ProBook 6460b Notebook PC, HP ProBook 6470b Notebook PC, HP ProBook 6560b Notebook PC, HP ProBook 6570b Notebook PC
Support Communication Cross Reference ID : IA03747895
