HP Scanjet Pro 3000 s2 - Scan to email
Scan to email
You must be connected to the Internet to complete this task.
To scan to an email, complete these steps:
  1. Place the document in the document feeder.
  2. In the Applications folder, double click the Image Capture icon.
  3. In the Image Capture window, select your scanner from the Devices list.
    For more Image Capture scanning options, click Show Details.
  4. Select Mail in the Scan To list to automatically attach the scan to an email message.
    If you use an email application other than Apple Mail, you can scan the document to a file and manually attach it to an email, or you can add your email application to the Scan To list.
    To add your email application to the list, select Other, select your email application, and then click Choose.
  5. On the resulting email message, enter the email address, subject, and any message text, and then send the email.
