HP Scanjet Pro 3000 s2 - HP EveryPage Ultrasonic
HP EveryPage Ultrasonic stops the scan process if it senses that multiple pages are fed into the scanner at one time. This feature is enabled by default.
You might want to disable this feature if you are scanning:
  • Multipart forms (a use that HP does not recommend).
  • Documents which have labels or sticky notes attached to them.
To disable HP EveryPage Ultrasonic, follow these steps:
  1. Open HP Easy Scan and select the shortcut for which you want to disable misfeed detection.
  2. From the Shortcuts menu, click Edit.
  3. On the Shortcut Editor dialog, click the Properties tab.
  4. Clear the Misfeed (multipick) detection check box.
    For detailed information on this feature and its options, see the HP Easy Scan Help.
Use the ISIS or TWAIN user interface to enable misfeed detection when scanning from non-HP software.
