HP Scanjet Pro 3000 s2 - Scan from HP Easy Scan
You can start a scan from the HP Easy Scan software.
  1. Do one of the following:
    • Double-click the HP Easy Scan icon on your desktop.
    • Windows XP, Vista, Windows 7: Click Start, point to Programs or All Programs, point to HP, point to HP Easy Scan, and then click HP Easy Scan.
    • Windows 8: On the Start screen, click the HP Easy Scan tile.
  2. Select a scan shortcut, and then click Scan.
    A description of the selected shortcut is displayed.
For more information, see the HP Easy Scan Help.
