    Fix HP Printer issue on macOS
HP All-in-One PCs - Fan is Noisy and Spins Constantly (Windows)
This document is for HP All-in-One PCs.
When a computer fan spins loudly for a long period of time, there might be an issue with a fan, or the computer might be overheating. Adjust the power settings, clean the fan vents, update the graphics driver, and then update the BIOS to help reduce the internal temperature.
It is normal for the fans to spin loudly for five to twenty seconds when the computer initially turns on.
Step 1: Adjust the computer power settings
Adjust the power settings to decrease power consumption, which can help the fans maintain an optimal internal temperature up to 30° C (86° F).
  1. Turn on the computer.
  2. In Windows, search for and open Control panel.
  3. In the Control Panel search field, type power options, and then select Power Options from the list.
    Selecting Power Options
  4. Click Change plan settings.
    Changing  the plan settings
  5. Click Change advanced power settings.
    Clicking Change advanced power settings
  6. Click the drop-down menu, and then select Power saver.
    Example of the power saver option in Windows 10
  7. Select Sleep from the list, and then click Sleep after and Hibernate after to open each setting.
    Sleep mode places the computer in a power-saving mode that does not close any open applications, while Hibernation mode saves any work in open applications, and then turns the computer off.
    Clicking the Sleep after and Hibernate after settings
  8. Decrease the amount of time for each setting to reduce unnecessary strain on the fans when the computer is not being used.
  9. Click OK to save the changes.
  10. Restart the computer.
If the issue persists, continue to the next step.
Step 2: Clean the air vents
Dust and debris can accumulate in and around the air vents over time, obstructing the airflow and causing the fans to work harder than normal to remove heat.
  1. Turn off the computer.
  2. Remove any objects near the computer.
  3. Use a vacuum to clean the vents at the back and sides of the computer.
    Location of the vents on an HP All-in-One PC
  4. Turn the computer on.
Step 3: Increase the efficiency to reduce heat
The computer works harder and generates more heat when multiple applications are open at the same time or while playing graphically intense video games.
Use the following tips to improve computer efficiency.
  • Change which applications run when Windows starts by using the Startup tab in Task Manager.
  • Close applications when you are done using them.
  • Close the Internet browser when you are not using it.
  • Lower the game resolution and decrease the graphics settings if the computer becomes warmer than usual while playing.
Step 4: Use Task Manager to identify corrupt processes
When the CPU is overburdened by multiple processes, such corrupt software or malware, the fans run continuously to remove the excess heat. Open Windows Task Manager to identify these processes, and then close them.
An unnecessary or corrupt process can consume anywhere between 1% to 100% of the CPU. Even a low but constant 3% to 4% load can cause the fans to spin faster.
  1. Make sure your computer is connected to a network with an active Internet connection.
  2. Press Ctrl, Alt, Delete, and then select Start Task Manager or Task Manager.
    Selecting Task Manager in Windows 10
  3. Click More details, if necessary.
    Selecting more details
  4. Click the Processes tab, and then click the CPU column header to sort the processes by CPU load.
    Clicking the CPU column header
  5. Use the Internet to research and confirm any suspicious processes that display in the list.
  6. Select the suspicious process, and then click End task.
If you did not find any suspicious processes or the issue persists, continue to the next step.
Step 5: Update the graphics driver
The graphics driver might be out-of-date. Use Windows Update to find and install updates for your computer.
HP does not recommend installing drivers from third-party websites, as this can create additional problems. If you choose to install a non-HP driver, make sure to create a Windows System Restore before starting the update. Go to Using Microsoft System Restore (Windows 10, 8) or Using Microsoft System Restore (Windows 7) for more information.
  1. Make sure the computer is connected to an active Internet connection.
    On a metered Internet connection, such as a cellular network, you might need to manually download updates.
  2. In Windows, search for and open Windows Update settings.
  3. Click Check for updates.
    • Windows 10: Any available updates install automatically.
    • Windows 7 and 8: Click Install Updates next to the available updates.
  4. After the updates install, restart your computer, if necessary.
Step 6: Update the BIOS
The computer BIOS might be out-of-date. Check for a BIOS update from HP.
Make sure you install the BIOS update for your specific computer model. Installing the wrong update can result in losing all computer functionality.
  1. Go to HP Software and Drivers Downloads, and then navigate to the product page for your computer.
  2. Locate BIOS in the list.
    • If the option is not available, the BIOS is up-to-date.
    • If the option is available, click BIOS, and then click Download next to the update. Follow the on-screen prompts, and then restart the computer. For more information, go to Updating the BIOS (Basic Input Output System).
If the BIOS is up-to-date or the issue persists, continue to the next step.
Step 7: Contact HP Customer Support
If all preceding steps did not resolve the issue, contact HP Customer Support for warranty and service options.
