HP Officejet Pro X476/X576 Multifunction Printer series - Overview
Product description
  • HP Officejet Pro X476dn - CN460A
  • HP Officejet Pro X476dw - CN461A
  • HP Officejet Pro X576dw - CN598A
Product features
Feature
X476
X576
Paper handling
  • Tray 1 (50-sheet capacity for 75 GSM or 20 lb Bond paper)
  • Tray 2 (500-sheet capacity for 75 GSM or 20 lb Bond paper)
  • Optional Tray 3 (500-sheet capacity for 75 GSM or 20 lb Bond paper)
  • ADF Feeder Tray (50-sheet capacity for 75 GSM or 20 lb Bond paper)
  • Standard output bin (250-sheet capacity for 75 GSM or 20 lb Bond paper)
  • Automatic duplex printing
Connectivity
X476dn
  • Hi-Speed USB 2.0
  • 10/100 Ethernet (wired) LAN connection
X476dw
  • Hi-Speed USB 2.0
  • 802.11 B/G/N Single Band wireless adapter
  • HP Wireless Direct printing
  • Hi-Speed USB 2.0
  • HP ePrint
Print
Plug and Print USB Drive printing (no computer required)
Copy
  • Copies at up to 20 ppm in black and 15 ppm in color
  • 50-page document feeder that supports page sizes from 127 to 356 mm (5 to 14 in) in length and from 127 to 216 mm (5 to 8.5 in) in width
  • Flatbed scanner supports page sizes up to 297 mm (11.7 in) in length and up to 215 mm (8.5 in) in width
  • Automatic duplex copying
Scan
  • Automatic duplex scanning
  • Scan to Memory Device (no computer required)
Fax
  • V.34 with an RJ-11 fax port
Software overview
Feature
Supported operating systems
  • Windows XP, 32-bit (Service Pack 2 or Higher)
  • Windows Vista, 32-bit and 64-bit
  • Windows 7, 32-bit and 64-bit
  • Windows 8, 32–bit and 64–bit
  • Windows 8 Pro, 32-bit & 64-bit
  • Mac OS X v10.6 and later
