    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Pavilion g6-2322tx Notebook PC Product Specifications
Product Name
g6-2322tx
Product Number
D5F58PA
2.6 GHz Intel Core i5-3230M
Microprocessor Cache
3 MB L3 cache
Memory
4 GB 1600 MHz DDR3
Memory Max
Upgradeable to 8 GB DDR3
Video Graphics
AMD Radeon HD 7670M (2 GB GDDR3 dedicated)
15.6" diagonal HD BrightView LED-backlit (1366 x 768)
Hard Drive
750 GB 5400 rpm SATA
Multimedia Drive
SuperMulti 8X DVD±R/RW with Double Layer Support
Network Card
Integrated 10/100 BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity
Bluetooth
802.11b/g/n
Sound
Altec Lansing Dual Speakers
PC Card Slots
Support SD/SDHC/SDxC, and MMC Supports mini versions of SD/MMC/MS adapters (adapter is not included) (note: SDxC support for capacity only, not speed)
External Ports
  • 2 USB 3.0
  • 1 VGA
  • 1 HDMI
  • 1 RJ-45 / Ethernet
  • 1 External Headphone-out
  • 1 External Microphone input
Dimensions
37.6 x 24.4 x 3.63 cm
Starting at 2.48 kg
Power
6-cell Li-Ion
What's In The Box
Webcam with Integrated Digital Microphone (VGA)
Operating System:
Windows 8 64 bits
Security and Support:
Multimedia and Entertainment (Software may vary in different countries.):
HP QuickWeb
HP Media Suite
Adobe Flash Player
Adobe Shockwave Player
Product Support (Software may vary in different countries.):
HP Setup
HP Wireless Assistant
HP Support Assistant
User Guide Documentation
