HP EliteBook 2570p Notebook PC - Removing and Replacing the Battery
This document pertains only to HP EliteBook 2570p Notebook PC with the following case design:
This document is provided to assist in removing and replacing the battery for the HP EliteBook 2570p Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
9-cell, 100 Wh, 3.00 Ah
632423-001 (Modified)
Yes
6-cell, 62 Wh, 2.80 Ah
632421-001 (Modified)
Yes
6-cell, 55 Wh, 2.80 Ah
632419-001 (Modified)
Yes
3-cell, 31 Wh, 2.80 Ah
632417-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Battery removal instructions
To view a video demonstrating the procedure for removing/replacing the battery, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Battery from the menu on the upper left hand side of the screen.
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to the product or loss of data.
The following video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
Step
Procedure
Instruction
1
Slide the battery release latch (identified with a battery icon) into the release position.
2
Slide the battery out of the battery bay.
Battery replacement instructions
To avoid damaging the battery locking mechanism, be sure that the battery release latch is in the unlocked position.
Step
Procedure
Instruction
1
Align the battery with the slide rails in the battery bay.
2
Slide the battery towards the front of the unit until it clicks into place.
3
Slide the battery release latch (identified with a battery icon) into the locked position.
Parts return
