HP Color LaserJet CM2320 Multifunction Printer (MFP) Series - How to Print an Engine Test Page
Environment
Questions/Symptoms
print an engine test page
check that the print engine works correctly
Cause
Answer/Solution
The engine test confirms that the print engine works correctly.
To print an engine test page, press the engine test button, which is located on the right side cover assembly of the printer (see Image 1) with a non-metallic object.
The engine test prints multiple horizontal colored lines (see Image 2) if the print engine works correctly.
