Removing and Replacing the Battery for HP Pavilion dv7-7000, dv7-7100 and HP ENVY dv7-7200, dv-7300 Notebook PCs
This document applies to HP Pavilion dv7-7x00 Series Entertainment and HP ENVY dv7-7x00 series notebook computers.
HP Pavilion dv7-7x00 series notebook computer
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the battery
  warning:
Follow the steps in this section to remove the battery.
Step 1
On the bottom of the notebook, slide the battery release latch into the release position to partially eject the battery.
The release latch is identified by a battery icon.
Sliding the release latch
Step 2
Lift the front end of the battery and remove from the computer.
Replacing the battery
Use the steps in this section to replace the battery.
Step 1
Toe the bottom outer edge of the battery into the battery bay.
Aligning the battery
Step 2
Press down on the inner edge of the battery until it clicks into place.
Pressing down on the battery
