Replacing Cartridges for HP Officejet 7110 Wide Format ePrinter Series
This document contains steps for replacing the cartridges in your HP printer.
Replacing cartridges
Follow these steps to replace one or more cartridges in the HP printer.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Open the cartridge access door.
    Image: Open the cartridge access door.
  3. Push in on the front of the cartridge to release it, and then pull it toward you to remove it from its slot.
    Figure : Remove the cartridge from its slot
    Image: Remove the cartridge from its slot.
  4. Remove the new cartridge from its packaging.
  5. Hold the cartridge so that the cartridge contacts are facing toward the printer.
  6. Slide the new cartridge into its slot, and then gently push it forward until it clicks into place.
    Make sure that the colored dot on the cartridge label matches the colored dot on the slot.
    Figure : Insert the cartridge into its color-coded slot
    Image: Insert the cartridge into its color-coded slot.
  7. Repeat these steps for other cartridges, if necessary.
  8. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door.
