HP ProBook 4545s Notebook PC - Removing and Replacing the Optical Drive
This document pertains only to HP ProBook 4545s Notebook PC with the following case design:
This document is provided to assist in removing and replacing the optical drive for HP ProBook 4545s Notebook PC.
Tools required
  • Phillips-head P1 screwdriver
  • Flat-bladed screwdriver
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Blu-ray ROM DVD±RW SuperMulti Double-Layer combination optical disk drive - SATA interface, 12.7mm tray load - Includes bracket, bezel, and screws.
683499-001 (Modified)
Yes
DVD±RW and CD-RW SuperMulti Double-Layer combination optical disk drive - SATA interface, 12.7mm tray load - Includes bracket, bezel, and screws.
683500-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Optical drive removal instructions
To view a video demonstrating the procedure for removing/replacing the optical drive, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Optical drive from the menu on the upper left hand side of the screen.
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to the product or loss of data.
Step
Procedure
Instruction
1
Remove the battery.
2
Remove the service door.
3
Remove the 6-mm P1 Phillips-head screw next to the optical disc icon.
4
Use a small, flat-bladed tool to push out on the metal tab on the rear of the optical drive to partially eject the optical drive from the base enclosure.
5
Grasp the optical drive bezel and pull the optical drive out of the optical drive bay.
Optical drive replacement instructions
Steps
Procedure
Instruction
1
Insert the optical drive into the optical drive bay until the connector is fully seated.
2
Replace the 6-mm P1 Phillips-head screw to secure the optical drive to the base enclosure.
3
Replace the service door.
4
Replace the battery.
Country: Flag Vietnam
