HP LaserJet Pro 500 color MFP M570 and HP LaserJet Pro MFP M435nw - Copy in draft mode
Copy in draft mode
Using draft mode can use less toner. However, using draft mode can also reduce print quality.
HP does not recommend the full-time use of draft mode. If draft mode is used full-time, the toner supply might outlast the mechanical parts in the toner cartridge. If print quality begins to degrade and is no longer acceptable, consider replacing the toner cartridge.
  1. Load the document onto the scanner glass or into the document feeder.
    Figure : Load the original document
  2. From the Home screen, touch the Copy button.
  3. Touch the Settings button.
  4. Scroll to and touch the Draft Mode button.
  5. Touch the On button.
  6. Touch the Black or Color button to start copying.
