    Fix HP Printer issue on macOS
HP LaserJet Enterprise 700 color MFP M775 - Staples (stapling models only)
Item
Part number
Staple cartridge
Each cartridge holds 5,000 unformed staples.
C8091A
For more information, go to www.hp.com/go/learnaboutsupplies.
Load staples
  1. Open the upper-right door.
    Figure : Open the upper-right door
  2. Pull the staple cartridge up and out to remove it.
    Figure : Remove the staple cartridge
  3. Insert the new staple cartridge into the opening. Press down on the top of the staple cartridge until it clicks into place.
    Figure : Insert the staple cartridge
  4. Close the upper-right door.
    Figure : Close the upper-right door
