HP PCs - Resolving Low Disk Space Issues and Errors (Windows 10, 8)
This document is for HP computers and tablets with Windows 10 or Windows 8.
When too little free space is available on your computer hard drive, Windows updates might not install, apps and files might not download, and low disk space errors or warning messages might display. The computer or tablet performance can also become unreliable.
If you are using an HP notebook PC with a 32 GB hard drive and have trouble upgrading due to low disk space, go to HP Notebook PCs - Freeing up Storage Space on a 32 GB Hard Drive (Windows 10).
If your computer is running Windows 8 and the error message You are running out of disk space on RECOVERY (D:) displays, go to HP PCs - Error: Low Disk Space. You are running out of disk space on Recovery (Windows 8) for more information.
Free up space on the hard drive
Empty the Recycle Bin, remove unwanted files and programs, and adjust System Restore settings to free up space on your hard drive.
Additional tips to free up space
Use the following procedures to prevent storage problems.
