Compaq R191 19-inch Diagonal LCD Monitor - Specifications
Physical specifications
Feature
Dimensions (h x w x d) (Unpacked)
449.6 x 190 x 362.6 mm (17.70 x 7.48 x 14.27 in)
Dimensions (h x w x d) (Packed)
510 x 119 x 422 mm (20.07 x 4.68 x 16.6 in)
Display head dimensions (w x h x d)
449.6 x 282.2 x 47.6 mm (17.70 x 11.11 x 1.87 in )
Bezel measurements
449.6 x 282.2 mm (17.70 x 11.11 in)
Weight (Unpacked)
2.7 kg (5.9 lbs)
Weight (Packed)
3.52 kg (7.7 lbs)
Weight (Head only)
2.54 kg (5.6 lbs)
Pallet specifications
Feature
Dimensions (L x W x H/D)
1030 x 1200 x 120 mm (40.55 x 47.24 x 4.72 in)
Total weight
367 ±2 kg
Layers
5
Product per layer
20 sets
Total products per pallet
100 sets
On Screen Display (OSD)
Feature
OSD user controls
  • Brightness
  • Contrast
  • Color
  • Image Control
  • OSD Control
  • Management
  • Language
  • Factory Reset
  • Source Control
  • Exit
User programmable modes
20
Monitor control buttons
  • Menu
  • "+" /Source
  • "OK"/Auto
  • Power button
Audio controls
No
Languages
  • English
  • German
  • Spanish
  • French
  • Italian
  • Simplified Chinese
  • Traditional Chinese
  • Japanese
  • Nederlands
  • Portugues
VESA mounting
No
Security lock
Yes
Electrical specifications
Feature
Power supply
Internal power supply
Power consumption max
22 W
Energy saving mode
0.5 W
Typical power consumption
20 W
ENERGY STAR data:
Operational Mode at 100 V ac
11.3 W
Operational Mode at 115 V ac
11.3 W
Operational Mode at 230 V ac
12.0 W
ENERGY STAR 5.0 "On State" power consumption
Yes
Environmental specifications
Feature
Temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (68° to 140°F)
Operating humidity
20% - 80% RH
Non-operating humidity
  • 80% - 95%
  • 38.7°C (101.66°F) max wet-bulb
LED backlights
Mercury-free LED backlighting
CCFL panel
No
Arsenic-Free glass
Arsenic-Free display glass
Lower power consumption (List reduced % compared to same size CCFL monitor)
Yes
Safety certifications
Feature
Agency approvals and certifications
  • CB
  • Energy star
  • ISC
  • PSB
  • BSMI
  • VCCI
  • C-Tick
  • CCC
Microsoft WHQL certification
Yes
ENERGY STAR compliant
Yes
EPEAT registered (List Bronze, Silver or Gold )
No
China energy label
Grade 1
TCO certified
No
SmartWay transport partnership
No
