HP Spectre XT Pro Ultrabook Specifications
Product image
Product features
Feature
Intel HM76 Express
Graphics
Intel HD Graphics 4000
Processor1
3rd Generation Intel Core i5-3317U (1.7 GHz, 3MB L3 cache, 2 cores)
  • Internal: 13.3-inch diagonal HD LED BrightView (1366 x 768)
  • External: Up to 32-bit per pixel color depth
  • HDMI: 1.4 port supports up to 1080p, 1920 x 1080 at 60 Hz
Memory2
DDR3L SDRAM (1600 MHz)
Internal storage device
128GB mSATA Solid State
Standard memory
Up to 4096MB
Keyboard
101/102-key compatible keyboard
Communications3
Integrated RTL8111 (10/100/1000 NIC)
1: Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
2: Maximum memory speed supported by the system may be 1333 MHz or 1066 MHz.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. With Windows Starter 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
3: The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Electrical specifications
Specification
Power supply
  • External 65-W HP non-Smart AC adapter
  • Power cord included is 1.8 m (6 ft)
  • Total length including external AC adapter is 3.66 m (12 ft).
Primary battery
HP 4-cell Lithium-Ion Battery (45 Whr)
Battery life1
Battery life up to 8 hours
System standby time
Up to 1 week
Stand-alone power requirements (AC power)
Nominal operating voltage
18.5 V
Max operating power
<65 W
1: Battery life will vary depending on the product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery will naturally decrease with time and usage.
Displays
Specification
13.3-inch LED HD (1366 x 768) BrightView
Dimensions (W x H)
29.3 x 16.5 cm (11.53 x 6.49 in)
Diagonal size
33.8 cm (13.3 in)
Surface treatment
BrightView
Contrast ratio
500:1 (typical)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.215 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
118 ppi
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum) or
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
Storage and drives
Specification
Internal storage
128GB 2.5-inch mSATA Solid State Drive
Drive weight
75 g
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 2
Performance
  • Maximum sequential read: 250 MB/s
  • Maximum sequential write: 140 MB/s
Logical blocks
250, 069, 680
Operating temperature
0° to 70°C (32° to 158°F) (case temp)
Features
  • ATA Security
  • ATA-7
  • SATA 2.6
  • DIPM
  • TRIM
Networking/Communications
Specification
Integrated Realtek RTL8111 10/100/1000 NIC
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (100BASE-T; IEEE 802.3ab; IEEE 802.3 clauses 21-30)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
Power management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame)
  • Wake-on-LAN from Off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface
PCI to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Realtek PCI FE Ethernet Family Controller
Intel Centrino Advanced -N 6235 802.11a/g/n (2x2) Bluetooth v4.0 combo adapter
Specification
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7
Frequency band
2.4 GHz and 5 GHz
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 300 Mb/s
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (collision avoidance)
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output power
13.5 dBm, nominal
Power consumption
  • Idle associated: 250 mW
  • Idle unassociated: 100 mW
  • Radio disabled: 75 mW
  • Transmit: 2.0 W (max)
  • Receive: 1.6 W (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
  • 54 Mb/s: -74 dBm
  • 11 Mb/s: -88 dBm
  • 1 Mb/s: -95 dBm
Antenna type
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express Half-MiniCard 1.2
3.7 g (0.008 lb)
Dimensions
26.80 x 30.00 x 4.75 mm (1.06 x 1.18 x 0.19 in)
Operating voltage
3.3 V +/-10%
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
Configuration utility
Microsoft Windows 7 Wireless Network Connection Manager
LED activity
  • Amber LED: Radio Off
  • White LED: Radio On
Bluetooth 4.0 Wireless Technology
Specification
Bluetooth specification
2.1+EDR, 3.0+HS, 4.0 compliant
Dimensions
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3, 64 kb/s, voice channels
  • Asynchronous Connection Less links 2.17 Mb/s/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
Max 4 dBm (Bluetooth Class II); Max +10 dBm (Bluetooth 4.0)
Better than -80 dBM at 0.1% raw bit error rate
Power consumption
  • Receive 230 mW
  • Peak Operating 330 mW
  • USB Selective Suspend 17 mW
Antenna
Range
Up to 9.14 m (30 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Motorola Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Temperature
Humidity
Altitude
Bluetooth profiles supported
  • Serial Port Profile (SPP)
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Audio/Multimedia
Specification
Implementation
IDT92HD99 High Definition CODEC
Function key volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array
Audio output quality
Frequency response
20 Hz to 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz to 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo speakers
Power rating
2 W
Impedance
4 Ohms
Power
Specification
HP 65-W non-smart AC adapter
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
  • 100 to 240 V ac
  • Input efficiency: 83% min at 115 V ac
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.7 A at 90 V ac, 0.85 A at 180 V ac
Output
  • Output power: 65 W
  • DC output: 18.5 V
  • Hold-up time: 5 ms at 115 V ac input
  • Output current limit: <5 A, Over voltage protection- 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating: 0° to 40°C (32° to 104°F)
  • Non-operating: -20° to 65°C (-4° to 149°F)
  • Altitude: 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 80%
  • Storage humidity: 10% to 90%
EMI and safety certifications
CE, UL, CSA or cUL, GS, Australian Electric Permit, C-tick, NOM, CCC, KC, GOST, SABS, S mark, BSMI, ISC, PSE, PSB and SII
HP 4-cell (45 Whr) Lithium-Ion primary battery
Dimensions (H x W x L)
1.4 x 5.2 x 20.6 cm (0.6 x 2.1 x 8.1 in)
Weight (max)
0.199 kg (0.44 lb)
Cells/Type
4-cell Lithium-Ion
Energy
  • Voltage: 10.8 V
  • Amp-hour capacity: 5.1 Ahr
  • Watt-hour capacity: 45 Whr
Temperature
  • Operating (Charging): 0° to 45°C (32° to 113°F)
  • Operating (Discharging): -10° to 50°C (-14° to 122°F)
  • Non-operating: -20° to 50°C (-4° to 122°F)
Battery re-charge time
  • System in Off or Standby Mode: 2.5 hours
  • System On: 3 to 5 hours
Fuel gauge LED
No
1 year
Physical specifications
Specification
Starting at 1.395 kg (3.07 lb)
Dimensions (W x D x H)1
31.65 x 22.45 x 1.45 cm (12.46 x 8.84 x 0.57 in) at front
1: Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 4-cell battery, solid state drive, 4GB memory, and no optical drive. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled Software with Windows Operating System
  • Microsoft Office Starter: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook.
  • HP Quick Launch
  • HP Support Assistant
  • HP CoolSense
  • Intel Wireless Display and Music
  • Skype ready (Internet access required)
  • Adobe Flash Player
Includes reduced functionality versions of Word and Excel. Purchase of Product Key required to activate full Office 2010 suite available at participating resellers/retailers and office.com.
Environmental specifications
Specification
Temperature
  • Operating:
    • 0° to 35°C (32° to 95°F) (not writing optical)
    • 5° to 35°C (41° to 95°F) (writing optical)
  • Non-operating: -20° to 60°C (-4° to 140°F)
Relative humidity
  • Non-operating: 5% to 95%, 38.7°C (101.6°F)maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 g
  • Non-operating: 1.50 g
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Operating temperature is de-rated 1.0°C/300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Safety certifications
Specification
Planned Industry Standard Certifications
  • UL - Yes
  • CSA - Yes
  • FCC Compliance - Yes
  • ENERGY STAR - Select models
  • EPEAT - Registered TBD in United States
  • ICES - Yes
  • Australia/NZ A-Tick Compliance - Yes
  • CCC - Yes
  • Japan VCCI Compliance - Yes
  • KC - Yes
  • BSMI - Yes
  • CE Marking Compliance - Yes
  • BNCI or BELUS - Yes
  • CIT - Yes
  • GOST - Yes
  • Saudi Arabian Compliance (ICCP) - Yes
  • SABS - Yes
  • UKRSERTCOMPUTER - Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
