HP Z220 Small Form Factor Workstation Product Specifications
Product description
HP Z220 SFF Workstation offers an array of choices from the new Intel Xeon processor E3-1200 v2 family and third-generation Intel Core processor family. This workstation features the latest Intel HD Graphics P4000 professional graphics option on selected Intel Xeon E3v2 processors, and a selection of entry, mid-range and high-end discrete graphics cards from NVIDIA and AMD, including support for the next generation PCIe Gen3 graphics cards.
Product features
Feature
Intel C216 chipset
Processors
Intel Xeon processor E3 v2 family (Z220):
  • Intel Xeon processor E3-1280v2, 3.6/4.0 GHz, 69 W, 8MB cache, 1600 MHz, Quad-Core, HT, featuring Intel vPro Technology
  • Intel Xeon processor E3-1270v2, 3.5/3.9 GHz, 69 W, 8MB cache, 1600 MHz, Quad-Core, HT, featuring Intel vPro Technology
  • Intel Xeon processor E3-1245v2, 3.4/3.8 GHz, 77 W, 8MB cache, 1600 MHz, Quad-Core, HT, Intel HD Graphics P4000, featuring Intel vPro Technology
  • Intel Xeon processor E3-1240v2, 3.4/3.8 GHz, 69 W, 8MB cache, 1600 MHz, Quad-Core, HT, featuring Intel vPro Technology
  • Intel Xeon processor E3-1230v2, 3.3/3.7 GHz, 69 W, 8MB cache, 1600 MHz, Quad-Core, HT, featuring Intel vPro Technology
  • Intel Xeon processor E3-1225v2, 3.2/3.6 GHz, 77 W, 8MB cache, 1600 MHz, Quad-Core, no HT, Intel HD Graphics P4000, featuring Intel vPro Technology
3rd generation Intel Core processor family:
  • Intel Core i7-3770 processor, 3.4/3.9 GHz, 77 W, 8MB cache, 1600 MHz, Quad-Core, HT, Intel HD Graphics 4000, featuring Intel vPro Technology
Dual-Core Intel Pentium processors (Z220):
  • Intel Pentium G640 processor, 2.8 GHz, 65 W, 3MB cache, 1066 MHz, Dual-Core, Intel HD Graphics 2000
CPU Bus speed
DMI
Processor socket
Single LGA-1155
Memory expansion slots
4 DDR3 memory slots
Memory type supported
DDR3, UDIMM (Unbuffered), ECC and non-ECC
Memory speed supported
DDR3 1600 MHz
Memory protection
ECC available on data
Maximum memory
32GB
Memory configuration (Supported)1
2GB, 4GB and 8GB ECC or non-ECC unbuffered DIMMs
Convertibility
The Z220 SFF can either be placed flat on the desktop or made to stand on the desk with the optional tower stand.
Color
Jack black
Multimedia and audio devices
  • HP Thin USB Powered Speakers, BFR-PVC free
  • Integrated Realtek HD ALC221 Audio
Controller cards
  • HP IEEE 1394b FireWire PCIe Card
  • HP USB 3.0 2 x 2 Port SuperSpeed PCIe x1 Card
Networking and communications
  • Integrated Intel 82579LM PCIe GbE Controller
  • Intel Gigabit CT Desktop NIC
Input devices
  • HP SpaceExplorer 3D USB Controller
  • HP USB Optical 3-Button Mouse
  • HP 2.4-GHz Wireless Keyboard and Mouse
  • HP USB CCID SmartCard Keyboard
  • HP USB 1000dpi Laser Mouse
  • HP PS/2 Keyboard
  • HP USB Optical Mouse
  • HP PS/2 Mouse
  • HP USB Keyboard
  • HP PS/2 Optical Scroll Mouse
Optical and removable storage
  • HP 16X DVD-ROM SATA Drive (non Lightscribe)
  • HP 16X DVD+/-RW SuperMulti SATA Drive (non-Lightscribe)
  • HP Blu-ray Writer
  • HP 22-in-1 Media Card Reader Kit (Workstations)
Monitors/Displays
  • HP DreamColor LP2480zx Professional Display
  • HP ZR30w 30-inch S-IPS LCD Monitor
  • HP ZR2740w 27-inch LED Backlit IPS Monitor
  • HP ZR24w 24-inch S-IPS LCD Monitor
  • HP ZR2440w 24-inch LED Backlit IPS Monitor
  • HP ZR2240w 21.5-inch LED Backlit IPS Monitor
  • HP ZR2040w 20-inch LED Backlit IPS Monitor
Graphics
Integrated Intel HD Graphics Media Accelerators (Z220):
  • Intel HD Graphics P4000
  • Intel HD Graphics 4000
  • Intel HD Graphics 2000
PCI connectors (5.0 V)
1 PCI LP slot
  • 1 PCIe Gen3 x 16 slot
  • 1 PCIe Gen2 x 4 slot /x16 connector
  • 1 PCIe Gen 2 x 1 slot
  • 1 PCI slots
Expansion bays
  • 3 internal 3.5-inch bays
  • 3 external 5.25-inch bays
Front I/O
  • 4 USB 2.0
  • 1 Headphone
  • 1 Microphone
Internal I/O
4 USB 2.0 ports available by two separate 9-pin headers
Rear I/O
  • 1 VGA and 1 DisplayPort output from Intel HD graphics (available on specific processors only)
  • 4 USB 3.0 ports
  • 2 USB 2.0 ports
  • 1 standard and 1 optional serial port
  • 1 optional parallel port
  • 2 PS/2
  • RJ-45 (NIC)
  • 1 Audio Line-in and 1 Audio Line-out
  • 2 IEEE 1394b ports(optional)
Interfaces supported
22-in-1 Media card reader (optional)
Power supply
240 W wide-ranging, active Power Factor Correction, 90% Efficient
1: Maximum memory capacities assume 64-bit operating systems, such as genuine Genuine Windows 7 Professional 64-Bit or Red Hat Linux 64-bit. 32-bit Windows Operating Systems support up to 4GB. ECC and non-ECC memory DIMMs cannot be mixed on the same system.
System specifications
Specification
System board form factor
ATX 244 x 305 mm (9.6 x 12 in)
PCI Express connectors
  • 1 PCI Express Gen3 x16 LP slot (x16 electrical/x16 mechanical)
  • 1 PCI Express Gen2 x16 LP slot (x4 electrical/x16 mechanical)
  • 1 PCI Express Gen2 x1 LP slot (x1 electrical/x1 mechanical)
HD Integrated audio
Yes
Flash ROM
Yes
CPU Fan header
Not applicable - passive CPU heatsink
Chassis fan header
Yes
Front control panel/speaker header
Yes
CMOS Battery holder - lithium
Yes
Integrated trusted platform module
Integrated TPM 1.2
The TPM module disabled where restricted by law, that is: Russia.
Power supply headers
Yes
Power switch, power LED and hard drive LED header
Yes
Clear password jumper
Yes
Keyboard/Mouse
USB or PS/2
Hood lock header
Yes (optional)
Built-in Self Test (BIST) LED
No
Surge tolerant full ranging power supply (withstands power surges up to 2000 V)
Yes
Electrical specifications
Specification
Operating voltage range
90 to 264 V ac
Rated voltage range
100 to 240 V ac
Rated line frequency
50 to 60 Hz
Operating line frequency range
47 to 63 Hz
Rated input current
4 A @ 100-240 V
Heat dissipation
  • Typical: 138 kg-cal/hr (546 btu/hr)
  • Maximum: 237 kg-cal/hr (941 btu/hr)
Power supply fan
92 x 25 mm variable speed
ENERGY STAR qualified (configuration dependent)
Yes
Physical specifications
Specification
Dimensions (H x W x D)
  • Standard desktop orientation: 100 x 338 x 381 mm (3.95 x 13.3 x 15.0 in)
  • Optional SFF Tower orientation (excluding stand dimension): 338 x 100 x 381 mm (13.3 x 3.95 x 15.0 in)
Weight (approximate)
  • Typical weight: 7.5 kg (16.5 lbs)
  • Shipping weight: 8.1 kg (17.86 lbs)
  • Maximum Supported Weight (desktop orientation): 35 kg (77 lb)
Configured with 1 3.5" hard drive, 1 optical drive, 2 DIMMs and 1 NVIDIA NVS 300 graphics card.
Software/OS
Feature
Operating systems supported
  • Genuine Windows 7 Enterprise 32/64
  • Genuine Windows XP Professional 32/64
Operating systems preinstalled
  • Genuine Windows 7 Ultimate 64-Bit
  • Genuine Windows 7 Professional 32/64
  • Genuine Windows 7 Home Premium 32/64
  • SUSE Linux Enterprise Desktop 11 64-bit
  • HP Installer Kit for Linux [includes drivers for 64-bit OS versions of Red Hat Enterprise Linux 6 and SUSE Linux Enterprise Desktop (SLED) 11]
  • Red Hat Enterprise Linux Workstation (1 year paper license available; Preinstall not available)
Environmental specifications
Specification
Operating temperature
5° to 35°C (40° to 95°F)
Non-operating temperature
-40° to +60°C (-40° to +140°F)
Operating relative humidity
8% to 85%, non-condensing
Non-operating relative humidity
8% to 90%, non-condensing
Operating altitude
3000 m (10,000 ft)
Non-operating altitude
9100 m (30,000 ft)
Cooling
Above 1524 m (5,000 ft) altitude, maximum operating temperature is de-rated by 1°C (1.8°F) per 305 m (1000 ft) elevation increase
Safety certifications
Specification
Energy star qualified (config dependent)
Yes
80 Plus compliant
Yes, gold
CECP Compliant at 220 V
Yes, configuration dependent
FEMP Standby power compliant
Yes, with Wake-on-LAN disabled
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
