Document ID: c03371733
Version: 1
HP Notebook PCs - HP Connection Manager Stops Responding After Install or Upgrade
Release date : 13-Jun-2012
Last updated : 13-Jun-2012
DESCRIPTION
After installing HP Connection Mananger (v3.x or v4.0 and later) on a notebook that already has HP Wireless Assistant, the newly installed HPCM stops responding when the program splash screen appears.
SCOPE
Compaq 320 Notebook PC
Compaq 325 Notebook PC
Compaq 420 Notebook PC
Compaq 421 Notebook PC
Compaq 510 Notebook PC
Compaq 511 Notebook PC
Compaq 610 Notebook PC
Compaq 615 Notebook PC
Compaq 620 Notebook PC
HP 420 Notebook PC
HP 421 Notebook PC
HP 425 Notebook PC
HP 620 Notebook PC
HP 625 Notebook PC
HP 635 Notebook PC
HP EliteBook 2540p Notebook PC
HP EliteBook 2740p Tablet PC
HP Mini 5101
HP Mini 5101
HP Mini 5102
HP ProBook 4310s Notebook PC
HP ProBook 4311s Notebook PC
HP ProBook 4320s Notebook PC
HP ProBook 4321s Notebook PC
HP ProBook 4410s Notebook PC
HP ProBook 4411s Notebook PC
HP ProBook 4415s Notebook PC
HP ProBook 4416s Notebook PC
HP ProBook 4420s Notebook PC
HP ProBook 4510s Notebook PC
HP ProBook 4515s Notebook PC
HP ProBook 4525s Notebook PC
HP ProBook 4710s Notebook PC
HP ProBook 5220m Notebook PC
HP ProBook 5310m Notebook PC
HP ProBook 5320m Notebook PC
HP ProBook 6440b Notebook PC
HP ProBook 6445b Notebook PC
HP ProBook 6450b Notebook PC
HP ProBook 6455b Notebook PC
HP ProBook 6540b Notebook PC
HP ProBook 6545b Notebook PC
HP ProBook 6550b Notebook PC
HP ProBook 6555b Notebook PC
HP Slate 500 Tablet PC
RESOLUTION
To resolve this issue, do the following:
  1. Click Start, type remove, then select Add or remove programs from the search results list.
  2. Select HP Wireless Assistant, then click Uninstall.
  3. After uninstalling HP Wireless Assistant, restart the notebook.
  4. When the notebook restarts, install HP Connection Manager.
The reason HP Wireless Assistant (HPWA) must be uninstalled is because it uses an older version of the HP Software Framework which HP Connection Manager (HPCM) is not allowed to replace. When HPCM tries run using the older software framework, it encounters an error and stops responding.
Removing HPWA first allows HPCM to successfully install all of its required components.
Hardware platforms affected : Compaq 320 Notebook PC, Compaq 325 Notebook PC, Compaq 420 Notebook PC, Compaq 421 Notebook PC, Compaq 510 Notebook PC, Compaq 511 Notebook PC, Compaq 610 Notebook PC, Compaq 615 Notebook PC, Compaq 620 Notebook PC, HP 420 Notebook PC, HP 421 Notebook PC, HP 425 Notebook PC, HP 620 Notebook PC, HP 625 Notebook PC, HP 635 Notebook PC, HP EliteBook 2540p Notebook PC, HP EliteBook 2740p Tablet PC, HP Mini 5101, HP Mini 5102, HP ProBook 4310s Notebook PC, HP ProBook 4311s Notebook PC, HP ProBook 4320s Notebook PC, HP ProBook 4321s Notebook PC, HP ProBook 4410s Notebook PC, HP ProBook 4411s Notebook PC, HP ProBook 4415s Notebook PC, HP ProBook 4416s Notebook PC, HP ProBook 4420s Notebook PC, HP ProBook 4510s Notebook PC, HP ProBook 4515s Notebook PC, HP ProBook 4525s Notebook PC, HP ProBook 4710s Notebook PC, HP ProBook 5220m Notebook PC, HP ProBook 5310m Notebook PC, HP ProBook 5320m Notebook PC, HP ProBook 6440b Notebook PC, HP ProBook 6445b Notebook PC, HP ProBook 6450b Notebook PC, HP ProBook 6455b Notebook PC, HP ProBook 6540b Notebook PC, HP ProBook 6545b Notebook PC, HP ProBook 6550b Notebook PC, HP ProBook 6555b Notebook PC, HP Slate 500 Tablet PC
Support Communication Cross Reference ID : IA03371039
