HP ProBook 6470b Notebook PC Product Specifications
Product description
Tailored for business. Optimized for Genuine Windows 7 Professional, this configurable notebook features a 14-inch diagonal display and UMA or discrete graphics. From the professional design to Intel technology, one is ready for business.
Product features
Feature
Processor1
  • 3rd Generation Intel Core i7-3520M (2.90 GHz, 4MB L3 cache, 35 W, 2 cores)
    • Up to 3.60 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3360M (2.80 GHz, 3MB L3 cache, 35 W, 2 cores)
    • Up to 3.50 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3320M (2.60 GHz, 3MB L3 cache, 35 W, 2 cores)
    • Up to 3.30 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3210M (2.50 GHz, 3MB L3 cache, 35 W, 2 cores)
    • Up to 3.10 GHz with Intel Turbo Boost Technology
  • 2nd Generation Intel Core i3-2370M (2.40 GHz, 3MB L3 cache, 35 W, 2 cores)
    • Intel Celeron B840 (1.90 GHz, 2MB L3 cache, 35 W, 2 cores)
  • Mobile Intel QM77 Express (vPro configurations)
  • Mobile Intel HM76 Express (non-vPro configurations)
Graphics
Integrated
  • Intel HD Graphics 4000 (3rd Generation Intel Core i7 and Core i5)
  • Intel HD Graphics 3000 (2nd Generation Intel Core i3)
  • Intel HD Graphics (Celeron configurations)
Discrete
  • AMD Radeon HD 7570M, with 1GB dedicated GDDR5 video memory
Internal
  • 14.0-inch diagonal LED-backlit HD 16:9 anti-glare (1366 x 768)
  • 14.0-inch diagonal LED-backlit HD+ 16:9 anti-glare (1600 x 900)
  • HP Privacy Filter support
External
  • Up to 32-bit per pixel color depth
DisplayPort
  • Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
VGA
  • Port supports resolutions up to 2048 x 1536 external resolution at 75 Hz
DVI-D (single link)
  • Video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking.
Storage and drives2
  • 320/500/750GB 7200 rpm SMART SATA II
  • 500GB 7200 rpm SMART SATA II self encrypting drive
HP 3D DriveGuard (Windows only)
  • The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
Solid State Drive
  • SATA 6 Gb/s 128GB Solid State
Optical drives
Fixed 12.7 mm (0.5 in) SATA optical drive
  • Blu-ray ROM DVD+/-RW SuperMulti DL drive
  • DVD+/-RW SuperMulti DL drive
  • DVD-ROM drive
Second hard drive
  • 500GB 7200 rpm SMART SATA II hard drive
  • Weight saver
Memory3
Standard
  • DDR3 SDRAM (1600 MHz)4
  • Two SODIMM slots supporting dual-channel memory
  • Standard memory up to 8192MB (2GB, 4GB, and 8GB SODIMMs)
Maximum
  • Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots
Networking/Communications
Wireless
  • Integrated WLAN and WWAN options
Mobile Broadband options
  • HP hs2350 HSPA+ Mobile Broadband module
  • HP un2430 EV-DO/HSPA Mobile Broadband module
Integrated wireless LAN options
  • Intel Centrino Advanced-N 6205 802.11 a/b/g/n (2x2)
  • Intel Centrino Wireless-N 2200 802.11 b/g/n (2x2)
  • Broadcom BCM943228HM4L 802.11 a/b/g/n WiFi adapter (2x2)
  • Atheros AR9485 802.11 b/g/n WiFi adapter (1x1)
  • HP integrated module with Bluetooth 4.0+ EDR Wireless technology
Communications
  • Integrated Intel 82579LM Gigabit5 network connection (vPro configurations)
  • Integrated Intel 82579V Gigabit5 network connection (non-vPro configurations)
  • 56K V.92 modem6
Audio/Multimedia
Audio
  • SRS premium sound
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone port
  • Stereo microphone port
Optional 720p HD webcam
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 f/s
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Keyboard
HP spill-resistant keyboard
Power
Power supply
  • External 90 W Smart AC adapter with discrete graphic models
  • External 65 W Smart AC adapter with integrated graphic models
Primary battery
  • HP 9-cell Lithium-Ion battery (100 WHr)
  • HP 6-cell Lithium-Ion battery (55 WHr)
  • HP 6-cell HP Long Life Lithium-Ion battery (55 WHr)
  • HP 3-cell Lithium-Ion battery (31 WHr)
Ports
  • VGA - One
  • DisplayPort - One (UMA: v1.1a; discrete: v1.2)
  • Stereo microphone port - One
  • Stereo headphone port - One
  • Power connector - One
  • Secondary battery connector - One
  • Docking connector - One
  • RJ-45 (Ethernet) - One
  • RJ-11 (Modem)- One
  • 1394a - One
  • USB 3.0 - Two
  • USB 2.0 - One
  • eSATA/USB 2.0 combo port - One
1. Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
2. Up to 19GB is reserved for the system recovery software.
3. Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. With Windows Starter 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
4. Maximum memory speed supported by the 2nd Generation Core i3 processor and the Celeron processor is 1333 MHz.
5. The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
6. Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
Technical specifications
Stand-alone power requirements (AC power)
Nominal operating voltage
18.5 V
Maximum operating power
<65 W or <90 W
Temperature
Operating
0° to 35°C (32° to 95°F) (not writing optical)
5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
14.0-inch LED HD (1366 x 768) anti-glare
14.0-inch LED HD+ (1600 x 900) anti-glare
Dimensions (W x H)
32.4 x 19.2 cm (12.74 x 7.56 in)
Diagonal size
35.6 cm (14.0 in)
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Anti-glare
Contrast ratio
400:1 (typical)
300:1 (minimum)
Refresh rate
60 Hz
60 Hz
Brightness
200 nit (typical)
200 nits (typical)
Pixel resolution
Configuration: RGB stripe
Format: 1366 x 768
Pitch: 0.227 mm (0.0089 in)
Format: 1600 x 900
Pitch: 0.1935 mm (0.0076 in)
Backlight
LED
LED
PPI
112 ppi
131 ppi
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum)
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
Storage and drive specifications
Internal storage
750GB 7200 rpm SATA hard drive
500GB 7200 rpm SATA hard drive
320GB 7200 rpm SATA hard drive
SATA 6 Gb/s 128GB, 2.5-inch Solid State Drive
Drive weight
101 g (0.22 lbs)
115 g (0.25 lbs)
115 g (0.25 lbs)
115 g (0.25 lbs)
73 g (.16 lbs)
Capacity
750GB
500GB
500GB
320GB
128GB
Height
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
7 mm (0.276 in)
Width
70 mm (2.75 in)
70 mm (2.75 in)
63.5 mm (2.50 in)
70 mm (2.75 in)
70 mm (2.76 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
SATA 3 (6 Gb/s)
Transfer rate(Synchronous: maximum)
300 MB/s (drive capability)
NA
Seek time (typical reads, including settling)
Single track: 1.5 ms
Average: 11 ms
Maximum: 22 ms
Average: 11 ms
Maximum: 22 ms
Single track: 1 ms
Average: 12 ms
Maximum: 20 ms
Average: 11 ms
Maximum: 22 ms
NA
Rotational speed
7200 rpm
7200 rpm
7200 rpm
7200 rpm
NA
Logical blocks
1,465,149,168
976,773,168
976,773,168
625,142,448
250,069,680
Operating temperature
0° to 60°C (32° to 140°F) [case temp]
0° to 70°C (32° to 158°F) [case temp]
Features
ATA security
ATA security
ATA security
ATA security
ATA security; ATA-8; SATA 3.0 DIPM; TRIM
Performance
NA
NA
NA
NA
  • Maximum sequential read: 415 MB/s
  • Maximum sequential write: 175 MB/s
Optical drives
DVD-ROM drive
Access times(Random)
  • <140 ms CD (typical)
  • <160 ms DVD (typical)
  • <190 ms CD-ROM (typical)
  • <180 ms DVD-ROM (typical)
  • <230 ms BD-ROM (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 6X - DVD+R dual layer
  • 6X - DVD-R dual layer
  • 5X DVD-RAM
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 4X - DVD+R dual layer
  • 4X - DVD-R dual layer
  • 5X DVD-RAM
  • 6X BD-ROM
Transfer mode
UDMA mode 5
UDMA mode 5
UDMA mode 5
Interface
Gen 1 SATA
Gen 1 SATA
Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
Supported media (write)
None
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM
Max media capacity (read)
8.5GB
8.5GB
50GB
Max media capacity (write)
NA
8.5GB
8.5GB
Transport
Tray loading
Tray loading
Tray loading
Audio/Multimedia specifications
Implementation
IDT 92HD87 High Definition CODEC
Function key volume controls
Volume up, volume down and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
DAC
16, 20 or 24 bit
ADC
16 or 20 bit
Internal stereo speaker
Power rating
2 W
Impedance
4 ohms
Power specifications
Power adapters
HP 90 W smart AC adapter (discrete configurations)
HP 65 W smart AC adapter (UMA configurations)
Dimensions
12.7 x 5.0 x 2.9 cm (5.00 x 1.97 x 1.1 in)
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
370 g (0.82 lb)
280 g (0.62 lb)
Input
100 to 240 V ac
100 to 240 V ac
Input efficiency
87% min at 115 V ac
87% min at 115 V ac
Input frequency range
47 to 63 Hz
47 to 63 Hz
Input AC current
  • 1.5 A at 90 V ac, 0.75 A at 180 V ac PFC version
  • 2.4 A at 90 V ac, 1.2 A at 180 V ac Non-PFC version
  • 1.7 A at 90 V ac
  • 0.85 A at 180 V ac
Output power
90 W
65 W
DC output
19.0 V
18.5 V
Hold-up time
5 msec at 115 V ac input
Output current limit
<11A, over voltage protection - 29 V max automatic shutdown
<11A, Over voltage protection - 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
0° to 40°C (32° to 104°F)
Non-operating (storage) temperature
-20° to 65°C (-4° to 149°F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
20% to 80%
Storage humidity
10% to 90%
10% to 90%
EMI and Safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
Battery
HP 9-cell (100 WHr) Lithium-Ion primary battery
HP 6-cell (55 WHr) Lithium-Ion primary battery
HP 3-cell (31 WHr) Lithium-Ion primary battery
Optional HP BB09 Ultra Extended Life notebook battery (secondary battery)
Optional HP ST09 Extended Life notebook battery (travel battery) (secondary battery)
Optional HP 6-cell (55 WHr) Long Life primary battery
Dimensions (H x W x L)
2 x 6.6 x 20.5 cm (0.8 x 2.4 x 8.1 in)
2.0 x 4.7 x 20.5 cm (0.8 x 1.8 x 8.0 in)
(2.0 x 4.7 x 20.5 cm (0.8 x 1.8 x 8.0 in)
3 x 15 x 29 cm (1.2 x 5.9 x 11.4 in)
3 x 15.5 x 30.5 cm (1.2 x 6.1 x 12 in)
Weight (max)
.488 kg (1.1 lb)
.313 kg (.70 lb)
.210 kg (0.47 lb)
.682 kg (1.5 lb)
.550 kg (1.2 lb)
.323 kg (.72 lb)
Cells/Type
Lithium-Ion
Lithium-Ion
Lithium-Ion
Lithium-Ion
Lithium-Ion Polymer
Lithium-Ion
Voltage
11.25 V
10.8 V
11.1 V
11.25 V
11.1 V
10.8 V
Amp-hour capacity
8.85 Ah
5.1 Ah
2.8 Ah
8.85 Ah
6.6 Ah
5.1 Ah
Watt-hour capacity
100 Wh
55 Wh
31 Wh
100 Wh
73 Wh
55 Wh
Operating temperature (Charging)
0° to 45°C (32° to 113°F)
Operating temperature (Discharging)
-10° to 50°C (14° to 122°F)
Non-operating temperature
-20° to 50°C (-4° to 122°F)
Battery re-charge time
  • System in OFF or Standby Mode: 3.5 to 5 hours
  • System ON: 4 to 7 hours
  • System in OFF or Standby Mode: 2.5 hours
  • System ON: 3 to 5 hours
Fuel gauge LED
No
No
No
Yes
Yes
No
Compatible with optional travel battery
Yes
Yes
Yes
No
Yes
Yes
Networking/Communication specifications
Intel 82579LM Gigabit network connection
Intel 82579V Gigabit network connection
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • Auto-negotiation (Automatic speed selection)
  • Full duplex operation at all speeds, half duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x flow control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo frame 9K
  • Auto MDI/MDIX crossover cable detection
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023 clauses 40)
  • Jumbo frame 9K
Power management
  • ACPI compliant - multiple power modes
  • Energy detect low power mode (green ethernet)
Performance features
  • TCP/IP/UDP Checksum offload (configurable)
  • Protocol offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving side scaling
  • MACSec offload (802.3ae)
  • Intel vPro
  • iSCSI boot
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 remote boot
  • Statistics gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for ethernet cable status
Interface1
PCI express 1.1 x 1 to fully support ASPM L0s/L1 and CLKREQ
Intel PCI express-base 1.1 x 1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Intel 82579LM/82579V ethernet network connection
1. Intel 82579 PCIe interface is not PCIe compliant. It operates at half of PCIe specification V1.1 (2.5GT/S) speed.
V.92 56K Data/Fax Modem
Specification
Form factor
MDC 1.5 daughtercard
Power management support
APM revision 1.2, ACPI
Approvals/Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Data mode capabilities
  • V.92 data
  • V.8bis
  • V.80
  • V44, V.42bis, MNP5 (compression)
  • V.42 (LAPM, MNP2-4) (error correction)
Optional symbol rates
  • 2800, 3429
  • Asymmetric Symbol rates
Synchronous primary channel data signaling rates
  • 3600, 31200
  • Automatic rate re-negotiation
  • V.34
  • V.32bis
  • V.32
  • V.23
  • V.22bis
  • V.22
  • V.21
  • Bell 212A
  • Bell 103J
Fax mode capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
  • T.31
Command set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
HP un2430 EV-DO/HSPA mobile Broadband module
HP hs2350 HSPA+ mobile Broadband module
Technology/Operating bands
  • GSM/GPRS/EDGE: 850 MHz (Cell), 900 MHz (EGSM), 1800 MHz (DCS), 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), AWS (UTRA FDD Band IV), 900 MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • 1xEVDO/1xRTT with receive diversity: 850 MHz (Band Class0-Cell), 1900 MHz (Band Class1-PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 Mhz (UTRA FDD Band II), 900 Mhz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class A, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9
  • UMTS/WCDMA: Release 99 and Release 6
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
  • GSM/GPRS/EDGE: Class B, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9
  • UMTS/WCDMA: Release 99 and Release 7
  • Advanced receiver Type 3i
Wireless parametric standards
Meets or exceeds TIA/EIA IS-98-D
Complies with 3GPP specifications
Maximum data rates
  • UMTS (HSPA) - 14.4 Mb/s (Download ), 5.76 Mb/s (Upload)
  • CDMA (EVDO Release A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
  • UMTS (HSPA) - 21 Mb/s (Download ), 5.76 Mb/s (Upload)
GPS
  • Standalone GPS enabled
  • gpsOneXTRATM
  • Standalone, A-GPS (Internet- and Network assisted)
GPS bands
L1 - 1575.42 MHz
1575.42 MHz (± 1.023 MHz)
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • CDMA: 24 dBm (+0.7/-2)
  • GSM/EDGE
  • GSM850 & GSM900 bands
    • GPRS: +33 dBm ± 2 dBm (class 4)
    • EGPRS: +27 dBm ± 3 dBm (class E2)
  • DCS1800 & PCS1900 bands
    • GPRS: +30 dBm ± 2 dBm (class 1)
    • EGPRS: +26 dBm +4/-3 dBm (class E2)
  • UMTS
  • UTRA FDD bands
    • +24 dBm +4 / -3 dBm (class 3)
Maximum power consumption
2750 mA (peak); 1100 mA (average)
2000 mA (peak); 600 mA (average)
Power consumption, idle not connected
20 mA
5 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
11.5 g
< 12 g
Dimensions (Length x Width x Thickness)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, operating
3.3 V +/- 10%
3.3 V +/- 9%
Temperature, operating (from TIA/EIA/IS-98-D)
  • -30° to 70°C (-22° to 158°F) (full RF performance)
  • -30° to 75°C (-22° to 167°F) (reduced RF performance)
  • -10° to 65°C (14° to 149°F) (full RF performance)
  • -10° to 75°C (14° to 167°F) (reduced RF performance)
Temperature, non-operating, 96 hours (from MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
-30° to 85°C (-22° to 185°F)
Humidity, non-operating
95% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
Configuration utilities
HP Connection Manager
LED activity
  • LED Off - Radio Off
  • Solid LED On - Radio On
Intel Centrino Advanced-N 6205 (2x2)
Broadcom BCM943228HM4L 802.11 a/b/g/n WiFi Adapter (2x2)
Atheros AR9485 802.11 b/g/n WiFi Adapter (1x1)
Wireless LAN standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP
  • Wi-Fi certified
  • Wi-Fi certified
  • Wi-Fi certified
Frequency band
2.4 GHz
2.4 GHz and 5 GHz
2.4 GHz and 5 GHz
2.4 GHz
Antenna structure
2 transmit; 2 receive (2x2)
NA
NA
Data rates
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: many possible data rates, ranging from 6 Mb/s to 300 Mb/s, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification.
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 66 possible data rates, ranging from 6 Mb/s to 300 Mb/s, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
  • 802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 6, 6.5, 9, 12, 13, 13.5, 18, 19.5, 24, 26, 27, 36, 39, 40.5, 48, 52, 54, 58.5, 65, 78, 81, 104, 108, 117, 121.5, 130, 135, 162, 216, 243, 270, 300 Mb/s
Frequency support
NA
NA
  • 20 MHz: 2.4 GHz and 5 GHz bands
  • 40 MHz: 2.4 GHz and 5 GHz bands
NA
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security1
  • Authentication: WPA and WPA2, 802.1x (EAP_TLS, TTLS, PEAP, LEAP, EAPFAST)
  • Authentication protocols: PAP, CHAP, TLS, GTC, MS-CHAP, MS-CHAPv2
  • Encryption: 64 and 128-bit WEP, AES-CCMP, CKIP, TKIP
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows Vista and XP only.
  • Supports 64 and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST
  • Supports 64 and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access point required)
Roaming
IEEE 802.11 compliant roaming between 2.4 GHz band access points.
IEEE 802.11 compliant roaming between access points.
Output power (for CCK and OFDM)2
15 dBm typical
17 dBm max
  • 17 dBm, nominal
  • 15 dBm, nominal (for OFDM; power varies by data rate)
13.5 dBm, nominal
Power consumption
  • Transmit: 1.4 W (average, with one spatial streams)
  • Receive: 1.3 W (average with two receive chains)
  • Idle mode3: 30 mW (average)
  • Radio off: 20 mW (max)
  • Transmit: 2.3 W (max, with two spatial streams)
  • Receive: 1 W (max with two spatial streams)
  • Idle mode3: 35 mW (average)
  • Idle associated: 250 mW
  • Idle unassociated: 150 mW
  • Transmit/Receive 20 MHz channel: 2.0 W (max)
  • Transmit/Receive 40 MHz channel: 2.0 W (max)
  • Transmit: 2.0 W (max)
  • Receive: 1.6 W (max)
  • Associated to access point, Idle: 250 mW nominal
  • Wireless button off: 100 mW nominal
  • Radio disabled: 75 mW nominal
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity4
54 Mb/s: -74 dBm, 6 Mb/s: -91 dBm
54 Mb/s: -76 dBm, 6 Mb/s: -92 dBm
270 Mb/s: -61 dBm, 54 Mb/s: -72 dBm, 11 Mb/s: -85 dBm , 1 Mb/s: -92 dBm
72.2 Mb/s: -70 dbm, 54 Mb/s: -74 dBm, 11 Mb/s: -88 dBm , 1 Mb/s: -95 dBm
Antenna connections
2 U.FL type connectors, 50 ohm nominal impedance
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure.
Form factor
PCI-Express Half-MiniCard
PCI-Express Half-MiniCard 1.2
3.4 g (0.0075 lb)
3.4 g (0.0075 lb)
6 g (0.013 lb)
6 g (0.013 lb)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating voltage
3.3 V +/- 9%
3.3 V +/- 9%
3.3 V +/- 10%
3.3 V +/- 9%
Temperature
  • Operating: 0° to 80°C (32° to 176°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
  • Operating: -10° to 65°C (14° to 149°F)
  • Operating: -10° to 70°C (14° to 158°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 0 to 3,048 m (10,000 ft)
  • Non-operating: 0 to 15,240 m (50,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
  • LED Off - Radio OFF
  • Solid LED On - Radio ON
1. Check latest software/driver release for updates on supported security features.
2. Maximum output power may vary by country according to local regulations.
3. In Power Save Polling mode and on battery power.
4. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
5. WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista.
HP integrated module with Bluetooth 4.0+EDR wireless technology
Bluetooth specification
4.0+EDR compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous connection oriented links up to 3, 64 kb/s, voice channels
  • Asynchronous connection less links 2178.1 kb/s per 177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep <1 mW
Antenna
Internally integrated within module
Range
Up 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power management
  • Microsoft Windows ACPI, and USB Bus support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Temperature
  • Operating: -10° to 70°C (-14° to 158°F)
  • Non-operating: -40° to 100°C (-40° to 212°F)
Humidity
  • Operating: 0% to 90%
  • Non-operating: 0% to 95%
Altitude
  • Operating: 4,572 m (15,000 ft)
  • Non-operating: 12,192 m (40,000 ft)
Bluetooth profiles supported
  • Serial Port Profile (SPP)1
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)1,2
  • Generic Object Exchange Profile (GOEP)
    1,2
  • Object Push Profile (OPP)1,2
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)1,2
  • Personal Area Networking Profile (PAN)1,2
  • Human Interface Device Profile (HID)1,2
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)2
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
1. Indicates that the profile is supported by Microsoft Windows XP SP2.
2. Indicates that the profile is part of Windows Vista.
Planned industry standard certifications
Certifications
Industry standard certifications
  • UL
  • CSA
  • FCC Compliance
  • ENERGY STAR (Select models)1
  • EPEAT (Registered Gold in United States)2
  • ICES
  • Australia / NZ A-Tick Compliance
  • CCC
  • Japan VCCI Compliance
  • KC
  • BSMI
  • CE Marking Compliance
  • BNCI or BELUS
  • CIT
  • GOST
  • Saudi Arabian Compliance (ICCP)
  • SABS
  • UKRSERTCOMPUTER
1. Configurations of the HP ProBook 6470b and HP ProBook 6570b that are ENERGY STAR qualified are identified as HP 6470b ENERGY STAR and HP 6570b ENERGY STAR on HP websites and on Energy Star website. Click here to access the Energy Star website.
2. EPEAT registration varies by country. Click here for registration status by country. EPEAT status listed above applies to U.S.
Physical specifications
Dimensions1 (w x d x h) (at front)
33.8 x 23.1 x 3.4 cm (13.31 x 9.11 x 1.34 in)
Weight1
Starting at 2.03 kg (4.48 lb)
1. Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and no optical drive. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled software with Windows operating system
  • HP Connection Manager
  • HP Hotkey Support
  • HP Power Assistant
  • HP ProtectTools for Central Management
  • HP ProtectTools Security Manager
  • HP Recovery Manager1
  • HP Support Assistant
  • HP Webcam Software (select models)
  • Adobe Flash Player
  • Corel WinDVD (select models)
  • Microsoft Office Starter: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook. Buy Office 2010 to use the full-featured software.2
  • Microsoft Security Essentials
  • PDF Complete Corporate Edition
  • Roxio MyDVD Business 2010 (select models)
  • Roxio Secure Burn (select models)
  • Skype ready (Internet access required)
  • UEFI 2.3 supported by BIOS
  • WinZip Basic
Additional software available from the web
HP SoftPaq Download Manager
1. HP Recovery Manager enables fast recovery of the factory preinstalled image if the system becomes corrupted or if important system files are accidentally deleted. Up to 19GB of the hard drive is reserved for the system recovery software. Support in Windows operating system only.
2. Includes reduced functionality versions of Word and Excel. Purchase of Product Key required to activate full Office 2010 suite available at participating resellers/retailers and Office website. Click here to access the Office website.
Environmental specifications
115 V ac
230 V ac
100 V ac
Energy consumption
Normal operation
8.6 W
9.27 W
8.32 W
Sleep (Energy Star low power mode)
0.6 W
0.7 W
0.6 W
Off
0.61 W
0.68 W
0.58 W
Heat dissipation1
Normal operation
29.4 BTU/hr
31.7 BTU/hr
28.4 BTU/hr
Sleep
2 BTU/hr
2.3 BTU/hr
2 BTU/hr
Off
2 BTU/hr
2.3 BTU/hr
2 BTU/hr
Declared noise emissions (in accordance with ISO 7779 and ISO 9296)
System fan off2
Sound power (LWAd, bels)
Sound pressure (LpAm, decibels)
Idle
3
26
Fixed disk (random writes)
3.4
26
1. Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
2. System fan is usually off except when charging the battery.
Security specifications
HP Fingerprint Sensor (optional)
Mobile voltage operation
3.0 V - 3.6 V single supply
0° - 70°C (32° - 158°F)
Current consumption @ 3.3 V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced power management
High-rate image capture
Up to 240 image frames/sec
ESD resistance
IEC 61000-4-2 Level 4 (±15 KV)
Detection matrix
  • 192 x 16 pixels
  • 9.7 x 0.81 mm
  • 500 ppi high-resolution images
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
