HP Photosmart 5520 Printers - Description of the Control Panel
This document is for HP Photosmart 5520, 5522, and 5525 e-All-in-One and HP Deskjet Ink Advantage 5525 e-All-in-One printers.
  • Touch the directional buttons to navigate between two home screens.
      Figure : The control panel of the HP Photosmart 5520 e-All-in-One series; HP Deskjet Ink Advantage 5525 e-All-in-One series
    1. 1 Home: Returns to the Home screen, the screen that is displayed when you first turn on the printer.
    2. 2 Help: On the Home screen, shows all Help topics. On another screen, shows information or animation on the display to assist in the current operation.
    3. 3 Directional Buttons: Allow you to navigate through two home screens, photos, print previews, apps, and horizontal menu options.
    4. 4 Back: Returns to the previous screen.
    5. 5 Cancel: Stops the current operation.
    6. 6 ePrint icon: Opens the Web Services Summary menu, where you can check ePrint status details, change ePrint settings, or print an Info page.
    7. 7 Wireless icon: Opens the Wireless Summary menu, where you can check wireless status and change wireless settings. You can also print a wireless test report, helping diagnose network connection issues.
    8. 8 Ink icon: Shows estimated ink levels by cartridge. Displays a warning symbol if the ink level is less than the minimum expected ink level.
    9. 9 Settings icon: Opens the Settings menu where you can change preferences and use tools to perform maintenance functions.
    10. 10 Photo: Opens the Photo Menu where you can view and print photos, or reprint a printed photo.
    11. 11 Apps: Provides a quick and easy way to access and print information from the web, such as coupons, coloring pages, puzzles, and more.
    12. 12 Copy: Opens the Copy menu where you can select a copy type or change the copy settings.
    13. 13 Scan: Opens the Scan menu where you can select a destination for your scan.
    14. 14 Quick Forms: Using HP Quick Forms, you can print calendars, check lists, games, notebook paper, graph paper, and music paper.
  • Wireless status light and button
    Figure : Wireless status light and button
    1
    • Solid blue light indicates that wireless connection has been established and you can print.
    • Slow blinking light indicates that wireless is on, but the printer is not connected to a network. Make sure your printer is within the range of wireless signal.
    • Fast blinking light indicates wireless error. Refer to the message on the printer display.
    2
    Wireless button
    Press the button to display wireless status, IP address, network name, hardware address (MAC), and Wireless Direct status.
Country: Flag Vietnam
