HP 2311gt 23-inch LED Backlit 3D Monitor - Overview
Product description
The HP 2311gt 23-inch LED Backlit 3D Monitor comes with two free pairs of lightweight 3D passive glasses that are comfortable to wear and provide an optimal 3D experience. It has Film Patterned Retarder (FPR) technology (with higher end graphics cards), making 3D viewing truly affordable.
Product features
Feature
Type
Twisted Nematic (TN) LED Backlit LCD
58.4 cm (23.0 in) widescreen; diagonally measured
Viewing angle (typical)1
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Viewing angle (3D)1
Up to 12° vertical
User programmable modes
Yes, 20
Anti-glare
Yes
Tilt range
0° to +25°
Swivel range
None
Height adjustable
None
Pivot rotation
None
Base and column
Both attachable, ships detached
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
