HP 450 Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP 450 Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
320GB, 5.4K-rpm, 2.5-inch form factor SATA hard disk drive (raw drive)
622643-001 (Modified)
Yes
750GB, 5.4K-rpm, 2.5-inch form factor SATA hard disk drive (raw drive)
634250-001 (Modified)
Yes
500GB, 5.4K-rpm, 2.5-inch form factor SATA hard disk drive (raw drive)
669299-001 (Modified)
Yes
640GB, 5.4K-rpm, 2.5-inch form factor SATA hard disk drive (raw drive)
669300-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Hard disk drive from the menu on the upper left hand side of the screen.
Hard disk drive removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Remove the memory cover.
  3. Remove the hard disk drive cover.
  4. Using the black Mylar tab on the hard disk drive adapter cable, disconnect the hard disk drive adapter cable from its connector on the system board.
  5. Grasp the rubber tab on the hard disk drive and lift the edge of the hard disk drive.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in a static-dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static-dissipative bag.
  2. Place the hard disk drive into the hard disk drive bay.
  3. Connect the hard disk drive adapter cable into its connector on the system board.
  4. Replace the hard disk drive cover.
  5. Replace the memory cover.
Parts return
