    Fix Windows 10 Update Issues
HP PCs - Updating Drivers and Software with Windows Update (Windows 10, 8, 7)
This document is for HP and Compaq computers and tablets using Windows 10, Windows 8, or Windows 7.
Windows Update is a tool that determines which updates apply to your computer and installs them. Downloading updates from Windows Update requires an internet connection.
You can also update drivers using Device Manager. For more information, go to Can I use Device Manager to get updates? in Frequently asked questions (FAQs).
Installing updates
Use these steps to install updates.
On a metered internet connection, such as a cellular data, you might need to manually download updates.
Review these frequently asked questions about Windows Update.
